976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 03:55 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  shimano MX hubs ??
Author Topic: shimano MX hubs ??  (Read 4090 times)
Offline kdw712
shimano MX hubs ??
« on: April 23, 2017, 06:11 PM »
 "help"
got these Gold Shimano hubs
thought they were DX but some digging about has shown they are MX hubs, HF-500
stamped up
FL  - Dec 1981
GA - Jan 1982
they have a 15 tooth gear and split ring
the cog will slide on and stop, but the split pin sits in a groove on the outer edge
so the cog is still free to slide sideways
is there a spacer or something that's required?
there's little info on the hubs let alone the parts ...
cheers Kev
Offline Avro
Re: shimano MX hubs ??
« Reply #1 on: April 23, 2017, 06:45 PM »
Is there a plastic castle thingy behind the sprocket? That could be what you are missing.
« Last Edit: April 23, 2017, 09:16 PM by Avro »
Wanted: Shimano Aero frame
Wanted: Tange Axeblade frame
Offline kdw712
« Reply #2 on: April 23, 2017, 09:46 PM »
That's what i  thought
Just not seen a complete set of MX hubs to confirm
« Last Edit: April 23, 2017, 09:48 PM by kdw712 »
cheers Kev
monkian
« Reply #3 on: May 31, 2017, 04:46 PM »
I took these from the JBM Catalogue (Jan 81). Hope they help ;)
monkian
shimano MX hubs ??
« Reply #4 on: May 31, 2017, 04:54 PM »
Looks like you've got the Model FH-MX60. Hard to see a collar on them. Is there room for another split-pin behind the cog?
Offline VOIVOD
« Reply #5 on: June 01, 2017, 12:22 PM »
 :) You should be able to easily get cassette spacers (even coloured ones) from any MTB shop that will stop the sliding and enable you to get perfect chain alignment.
Offline kdw712
« Reply #6 on: June 03, 2017, 10:51 AM »
Good idea.  :daumenhoch:
A trip to the LBS
Hub in hand
cheers Kev
