976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 10:36 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dia Compe Tech 7 restoration
Author Topic: Dia Compe Tech 7 restoration  (Read 8982 times)
Offline tfi_friday
« on: May 14, 2017, 02:07 PM »
I've restored a few sets of these now and it's relatively straight forward but the prices of Tech 7s are a bit silly for a clean set so to clean up might save a few quid.
Here's what I started with. They came on an 1987 GT PFT I picked up for £40 (complete bike)
Not in bad shape, but I need a white/silver for my next build and there's heavy rust on the locking pins.
That's where I started first remove the locking pin spring and to dremel the rust off the top of the locking pin as best I could. Stuck the spring in Citric Acid at the same time.
To get a nice finish on the bolts and locking pin I put the end of it in a drill and spin it around against sand paper. Works great and fast to do.
With that done, it's to remove the paint (black is paint not anodiized)
Then it's just to clean it up and remove the small blemishes from the body and levers.
All done and ready for paint/powder
Here's a couple of sets I restored earlier
« Last Edit: May 14, 2017, 02:12 PM by tfi_friday »
Offline Andyboy77
Re: Dia Compe Tech 7 restoration
« Reply #1 on: May 14, 2017, 02:32 PM »
Excellent job and guide!  :4_17_5:  fistblump
« Reply #2 on: May 14, 2017, 09:52 PM »
Very nice.  :coolsmiley:
« Reply #3 on: May 14, 2017, 09:56 PM »
Nice work  :4_17_5:
Offline CustardLips
« Reply #4 on: May 14, 2017, 10:22 PM »
Bolts, drill and sand paper... great tip.  :daumenhoch:
"WWG1WGA"
Offline Taipan
« Reply #5 on: May 14, 2017, 10:49 PM »
« Last Edit: May 14, 2017, 10:55 PM by Taipan »
Offline tfi_friday
« Reply #6 on: May 15, 2017, 09:30 AM »
Gives a nice brushed finish...
A bit of autoglym and a rad will polish them up also (just watch the rag and the drill)
Offline tfi_friday
« Reply #7 on: May 15, 2017, 11:16 AM »
Ready for paint :-)
Offline deeman
« Reply #8 on: May 15, 2017, 11:20 AM »
Great work Alan  :daumenhoch:
Offline tfi_friday
« Reply #9 on: May 15, 2017, 01:56 PM »
cheers :-)
They're turning out nicely.
Cleaned up the levers since they won't be painted and started painting the bodies.
Offline tfi_friday
« Reply #10 on: May 15, 2017, 05:28 PM »
...and done!
Offline brimfull
« Reply #11 on: May 07, 2018, 11:55 AM »
Hi Alan, sorry to drag this up but I've just bought some that need restoring. How do you get the locking lever and spring off and back on - do you need a press or something?
Offline kalex
« Reply #12 on: May 07, 2018, 12:48 PM »
Blimey how a year flys by, I thought this was a recent thread until I saw the date.
Offline tfi_friday
« Reply #13 on: May 09, 2018, 01:42 PM »
The spring is easy to remove, just pop if the start of the sprint over the lip of the locking button and move the spring round and around the locking button till it comes off.
The locking button can be painted/powdered without removal.
The lever is bolted in place... not a rivet like Tech 3
Offline brimfull
« Reply #14 on: May 09, 2018, 10:51 PM »
Thanks dude  :nuts:  fistblump
Offline Taipan
« Reply #15 on: May 10, 2018, 05:23 PM »
Is that a pair of your refurbished levers on ebay for £350  :shocked:
Offline PHIL9HUF
« Reply #16 on: May 11, 2018, 01:11 AM »
Great job Alan  :daumenhoch:
Didn't they only make them for 1 year ?
Hence not too many about that makes them expensive !
Offline tfi_friday
« Reply #17 on: May 12, 2018, 06:41 PM »
Nope all mine in use :-)
£350??? Bloody Nora
Offline tfi_friday
« Reply #18 on: May 12, 2018, 06:42 PM »
Think it was a couple of years, but they broke at the clamp which also makes them a tough find
« Last Edit: May 13, 2018, 06:46 PM by tfi_friday »
Offline PHIL9HUF
« Reply #19 on: June 08, 2018, 01:06 AM »
There is a nos pair in an auction on eBay for over £900!
