976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 03:08 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Profile crank axles
Author Topic: Profile crank axles  (Read 2929 times)
Offline SH101
Profile crank axles
« on: May 17, 2017, 01:55 PM »
Hello chaps ,
I have a 19mm 48 spline axle for my Profile cranks , it`s hollow ( and so are the bolts that go with it ). The problem is the length , it`s only 130mm . The one I need is more like 150mm . Does anybody know if any of the cheaper axles fit ?
Thanks for your help
Looking for Blue and Lavender metal hubbed orphan rear Tuff 2s ... help !
Re: Profile crank axles
« Reply #1 on: May 17, 2017, 04:22 PM »
I think Gusset do one that's 19mm and 48 splined if i remember correctly??
Offline SH101
« Reply #2 on: May 17, 2017, 05:00 PM »
Cheers for the reply
I`ve just had a look at the gusset one ... still only 136mm though  :(
« Reply #3 on: May 17, 2017, 06:09 PM »
ahhh bugger, sorry  :-\
« Reply #4 on: May 17, 2017, 06:11 PM »
Offline Bigfrawg
« Reply #5 on: May 17, 2017, 07:06 PM »
Silly question but why so long ?
Offline fugazi
« Reply #6 on: May 17, 2017, 07:07 PM »
19mm 48 spline axles are widely available in 145mm & you'd think they would be the same but I tried it with a non Profile axle & the arms were a little loose on the axle. I have no idea why & maybe you'll have more luck  :LolLolLolLol:
Offline VOIVOD
« Reply #7 on: May 17, 2017, 09:16 PM »
 Not so silly at all:) A lot of modern street/park frames have wider stays to accomodate the tractor sized tyres.Standard length axles don`t always allow the arms to be spaced widely enough apart without having just a couple of mm inside the crank arm.
Offline SH101
« Reply #8 on: May 18, 2017, 08:29 AM »
Exactly that ! I`m just trying to get the crank arms to clear the stays .
