976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 12:35 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  gt tour 2 (bringing back t life) first full build (budget build)
Author Topic: gt tour 2 (bringing back t life) first full build (budget build)  (Read 2028 times)
Offline Alpinesurfer
 :idiot2:
Im in the very early stages of getting my old gt tour 2 back on the road after getting it back in a mess years after selling it.
I got hold of some wheels and some other bits.
i had an hour free this weekend so thought i would get started .
So i thought i would bang the wheels on to see whats what and realised the wheels are 14mm and bike is 10mm i think .. :-/
So do i now have to sort axels out somehow on both wheels or drill the frame and forks ?
cheers for any help
Offline CustardLips
Don't drill the dropouts out... get a different wheelset.  :daumenhoch:
"WWG1WGA"
Offline oldtired
  • Dirty Old Man
change the wheels, or just the hubs,    at worst slot the axles to fit the 3/8th  (10mm) dropouts ,  DON'T cut ,drill, grind out the dropouts on the frame !!!!  "nono" "nono"   unless your having them machined professionally,   it's difficult to get right,    even then having them machined professionally  is a real bad idea !
So i can't just bang some 10 mm axels inside then?
Offline fugazi
What hubs are you using & are the axles solid or hollow?
Not sure i will investigate ?
Front axel is 10mm solid rear is 14 and seems hollow (sounds it when i tap it with spanner)  so need rear to be 10mm) i picked up a job lot of bits including 2 nice looking wheels clean not bent etc nice tyres .
so now I'm not sure if i can bang an axel in it for 10mm ?????
or just more simple to get a single back non matching wheel?
cheapest option wins..
if after i get it on the road i find i have money i can change or upgrade later
