976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 03:53 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Gen 1 gyro help
Author Topic: Gen 1 gyro help  (Read 2026 times)
Offline Quadog
Gen 1 gyro help
« on: October 07, 2017, 03:06 PM »
Hi All
Started to put together my 87 Master and straight away I've come across a problem I cant seem to get enough Thread to attach lock nut I've never done this before and have no instructions seen a few pics on net but that's about it can anyone help me out with some advice and show me where I'm going wrong
Cheers Scott
Offline oldtired
  • Dirty Old Man
Re: Gen 1 gyro help
« Reply #1 on: October 07, 2017, 04:25 PM »
have you used the keyed washer that usually goes between the top race and the locknut ?
Offline That Swan Guy
Re: Gen 1 gyro help
« Reply #2 on: October 07, 2017, 04:32 PM »
As Jim said, remove all spacers/washers from original headset as the plate will replace it
Offline Quadog
Re: Gen 1 gyro help
« Reply #3 on: October 07, 2017, 04:37 PM »
Yes I removed original washer I'm thinking it could be the first few threads of lock nut that might be worn rummaging round for another see if it helps
Cheers Scott
Offline oldtired
  • Dirty Old Man
Re: Gen 1 gyro help
« Reply #4 on: October 16, 2017, 10:11 PM »
you may need to find a top race without the  nut on it,   just with the knurled bit and the keyed washer,  preferably a race with a flush fit wahser,  had to do this in the past on some forks with shorter threads,
 ideally you want the fork thread almost to the top of the top lock nut when tightend up  :daumenhoch:
Offline Andyboy77
Re: Gen 1 gyro help
« Reply #5 on: October 16, 2017, 10:50 PM »
I'm missing the moving bit. Don't know if your Gyro came with a instalation instruction, so I hope this is of any use to you.  :daumenhoch:
