976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 05:41 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  New school brakes on old school ride....
Author Topic: New school brakes on old school ride....  (Read 5905 times)
lloydieboy
« on: September 14, 2005, 12:36 PM »
Does anyone know if you can buy any type of bracket that can be fitted to an old school bike but will give you the lugs to fit new school brakes onto it?
Got an old CW Freestyler that i'd like to fit new centre pull brakes on but not quite sure how i could get round it.
And i really don't want to go welding bits onto the frame....
Cheers,
Lloyd.
Offline kdw712
cheers Kev
Offline ORB
Re: New school brakes on old school ride....
« Reply #2 on: September 14, 2005, 12:43 PM »
that is a large link.
12
Offline kdw712
« Reply #3 on: September 14, 2005, 01:26 PM »
lol
"scrolling scrolling scrolling keep those links scrolling "
tis a tad long isn't it  :D
how about
Quick link
cheers Kev
« Reply #4 on: September 14, 2005, 01:31 PM »
bastard. im gonna think about that scrollin song every time i do it now.
Offline Rombloke
  • do one
« Reply #5 on: September 14, 2005, 04:05 PM »
yeah the plates work ok but you have to use jubilee clips as well as the centre bolt to stop the plate flexing
Dave
haro, how do you do
« Reply #6 on: September 14, 2005, 04:42 PM »
i just bought a u brake plate. it will not flex. its 5mm thick and weighs more than the forks its going on ( almost ;) )
i had one before on my redline rl240 back in 96. they work fine.
the v brake ones however do require jubilee clips. they look awful too - huge! get a u-brake plate and nice dia compe brake. sorted. dont forget to run a good lever too!
Sanmarcopizza
« Reply #7 on: September 14, 2005, 04:47 PM »
The plate itself shouldn;t bend, but you may find the through bolt or brake bridge will give. Clips or at the very least thick zip ties recommended.
« Reply #8 on: September 14, 2005, 04:49 PM »
i want to mount a u brake plate on the rear of a mongoose cali
where / how can i mount the cable (before the centre pull thingy) ???
is there a "thingy" i can buy?
Offline kdw712
« Reply #9 on: September 14, 2005, 05:01 PM »
Another option may be too :
get a pitbull calliper from cyclesport.co.uk - £7ish
 kinda inbetween new and old - single bolt fixing and centre pull power
or get a ACS boa they will stop a truck
cheers Kev
Sanmarcopizza
« Reply #10 on: September 14, 2005, 05:36 PM »
I guess the thingy you need would be an odyssey pozistop
Offline Rombloke
  • do one
« Reply #11 on: September 14, 2005, 05:52 PM »
its not the plate that flexes but the fact that its only connected by a bolt at the top....the lugs are nr the bottom....therefore the old fulcrum/lever effect comes into play....believe me you need to jubilee clip it...or as san says zip ties...although i used one of these plates on rhys's last bike and he was forever snapping zip ties...
Dave
haro, how do you do
lloydieboy
« Reply #12 on: September 14, 2005, 07:24 PM »
Cheers for the link. Could these be used for both front and back brakes????
Lloyd
I think you need a U or V brake plate
single bolt to frame and plate has canti posts fixed to it
try this link
http://www.winstanleysbmx.com/index.html?9gaoaMNAq+gC6Gw5UfkpFtOZoUaSe1rVolSbJwWnUD087LlnEUfhkb3FVIxaECEG56pmDyNa5E/OaIGYIzmVqtKBkQUQwUmUA4cFOvjt2d0LlxdL25V6u7KwJVSzXfaqA9iHtaw5vqS6U71vrZt09Ckxz8kZKmW47THsIVJ2Qow=
Sanmarcopizza
« Reply #13 on: September 14, 2005, 10:11 PM »
Here you go, an example of the set up at the rear.
You will need a pozistop (look at the seat clamp) it's a cable hanger integrated into the seat clamp.Probably need to get one from the USA. OT cycles has one in blue for about £12. You need to buy a specific front brake for the front as the cable will come into i from the side not the centre. An Odyssey Evolver comes with all the stuff for front or rear, as does a Primo E Brake, but Hombre's are specific for front or rear.
« Last Edit: September 15, 2005, 11:50 AM by Sanmarcopizza »
Offline ORB
« Reply #14 on: September 14, 2005, 10:15 PM »
Sandro.
SORT THEM DECALS OUT!!!!!!!!!!!!!!!!
12
« Reply #15 on: September 15, 2005, 08:24 AM »
spot on nice one
thats exactly what i need!
Sanmarcopizza
« Reply #16 on: September 15, 2005, 11:48 AM »
Oli, haven't got a clue what you're on about  ;D
« Reply #18 on: September 15, 2005, 12:47 PM »
Offline kdw712
« Reply #19 on: September 15, 2005, 01:17 PM »
Are they the new skyway jelly wheels ???  ;) ;D
cheers Kev
« Reply #20 on: September 15, 2005, 01:31 PM »
yep rare chivers edition
motomagII
« Reply #21 on: September 18, 2005, 05:30 PM »
jelly wheels probably less flex than tuffs lol ;D ;D ;D ;D ;D
