New school brakes on old school ride....
<< < (2/5) > >>
Rombloke:
yeah the plates work ok but you have to use jubilee clips as well as the centre bolt to stop the plate flexing
Dave
theRuler:
i just bought a u brake plate. it will not flex. its 5mm thick and weighs more than the forks its going on ( almost ;) )
i had one before on my redline rl240 back in 96. they work fine.
the v brake ones however do require jubilee clips. they look awful too - huge! get a u-brake plate and nice dia compe brake. sorted. dont forget to run a good lever too!
Sanmarcopizza:
The plate itself shouldn;t bend, but you may find the through bolt or brake bridge will give. Clips or at the very least thick zip ties recommended.
theRuler:
i want to mount a u brake plate on the rear of a mongoose cali
where / how can i mount the cable (before the centre pull thingy) ???
is there a "thingy" i can buy?
kdw712:
Another option may be too :
get a pitbull calliper from cyclesport.co.uk - £7ish
 kinda inbetween new and old - single bolt fixing and centre pull power
or get a ACS boa they will stop a truck
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
