976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 08:15 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  95 Mongoose Hooligan citric acid bath process
Author Topic: 95 Mongoose Hooligan citric acid bath process  (Read 6753 times)
« on: July 25, 2019, 02:40 AM »
Massive thanks to 'Michael Bmx' for this 1995 Mongoose Hooligan survivor.
95 saw the launch of the DMC bike so the Hooligan is often overlooked and as a result there's not many about.
Here's the bike from Michael's pictures ... a bit of love and few replacement parts were in order
and how it arrived with me
I took pics of the citric acid bath clean up and rust removal steps for instagram so here goes :-)
« Last Edit: July 25, 2019, 07:01 AM by ED209 »
Re: 95 Mongoose Hooligan basic resto
« Reply #1 on: July 25, 2019, 02:47 AM »
First step was to fully strip the bike and decide what I needed to replace - the chainwheel and crank were bent and the seat was trashed. The front wheel had been replaced at some point but replacing that wasn't vital.
second step - 'Gunk' everything ( other degreasers are available - I'd avoid petrol ) to remove the oil, tar & general crap followed by a soapy water wash before it goes into the citric acid bath.
Note the condition of the frame under the platform ... that was the worst bit.
« Last Edit: July 25, 2019, 07:03 AM by ED209 »
« Reply #2 on: July 25, 2019, 06:49 AM »
step 3 - Citric acid bath
Either buy a suitable container or make yourself a bath ... I buy a cheap tarpaulin from Wilko and 'borrow' a drawer from somewhere :-)
I always use 500g of Citric powder mixed with hot water for a frame sized container - the bricks fill up the space so the mixture stays strong and I keep filling till its all covered - I usually leave the rusty parts in for up to 12 hours but I check regularly - these were only lightly rusted so they were done after 5/6 hours.
I don't like messing about so I usually put everything in ... it gets the rust out of bolt heads and brake adjusters ... even gyro cable ends ... rust marks off alloy ... and YES as you will see ... your decals stay untouched.
Here's an action shot :-) the rust fizzes away ... no rubbing ... no effort ... NO COLLUSION!
When they are done all the parts need a good rinse with washing up liquid and water and left to dry before the final stage
« Last Edit: July 25, 2019, 07:04 AM by ED209 »
Re: 95 Mongoose Hooligan citric acid bath process
« Reply #3 on: July 25, 2019, 07:12 AM »
Final stage before rebuild is to polish and protect the parts ... I use Peek.
The can says put it on with a cloth but I always use my hands ... which means you use loads less as it doesn't absorb into your hands like a cloth would ... and you can use your fingers to get the polish into all those hard to reach places  :angel:
I then use a soft cloth to rub the polish off ( don't let it dry ) and then a different clean soft cloth to finish it.
So here's that rusty bit under the platform again ...
The citric acid can't replace lost chrome but it can get rid of ALL the rust to give you the best 'survivor' condition possible ... and the Peek seals the raw bits ... you can see theres still a bit of pitting in the chrome but I can live with that ... if you can't then you just need a little time to get the anal obsession with pefection out of your system  :laugh:
Did a quick rebuild to see how it looked  8) 8) 8) 8)
« Last Edit: July 25, 2019, 07:19 AM by ED209 »
Offline hotdog
« Reply #4 on: July 25, 2019, 07:34 AM »
Excellent. Are you gonna ride it Ed?
Offline dp and chopper dude
« Reply #5 on: July 25, 2019, 10:18 AM »
Spot on. That's looking great  8)
Offline Mikku
  • Keeping it RAD in Japan!
« Reply #6 on: July 25, 2019, 12:07 PM »
Came up a treat! :daumenhoch:
« Reply #7 on: July 25, 2019, 02:05 PM »
Gonna roll it round at MK  fistblump
« Reply #8 on: July 25, 2019, 04:26 PM »
top job that Ed  :coolsmiley:
