976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 04:25 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuff Brake Rub
Author Topic: Tuff Brake Rub  (Read 7598 times)
Offline Chilli Rinse
Tuff Brake Rub
« on: February 23, 2020, 04:56 PM »
Hi guys, I’ve bought a nice used pair of Skyway 24 Tuff II’s in white. They were from a really nice seller and I got a great deal seeing as they came with DMR Supermoto’s fitted. He didn’t hide anything as brake rub was mentioned and there were pics of it on the rear wheel too. Problem is blue Skyway tuff pads were used on white wheel, and possibly clear pads after the blue. I thought it would be just colour transfer but there is a plastic like build up on the rim from the pads where the spokes are.
So I have 2 questions...
1. Is there a trick to get this build up off and remove the blue marks without scraping and damaging the rim?
2. Is there a better brake pad to use once I’ve cleaned the rim, maybe Cool Stop or Z pads in white?
Any help would be appreciated
Re: Tuff Brake Rub
« Reply #1 on: February 23, 2020, 07:53 PM »
Razor blade it is then  :LolLolLolLol:
Offline Ady
Re: Tuff Brake Rub
« Reply #2 on: February 23, 2020, 10:04 PM »
Offline Ady
Re: Tuff Brake Rub
« Reply #3 on: February 23, 2020, 10:09 PM »
Deffo razor blade
Re: Tuff Brake Rub
« Reply #4 on: February 23, 2020, 10:16 PM »
Cheers dude, I found that after I posted on here. I was hoping there was a chemical you could use to loosen it up a bit. Not sure what soft scrub is either, or an equivalent available over here. This stuff is welded on good.
Offline Picklez
Re: Tuff Brake Rub
« Reply #5 on: February 24, 2020, 12:12 AM »
maybe a little hair dryer treatment to soften it up first  :-\
Re: Tuff Brake Rub
« Reply #6 on: February 24, 2020, 07:02 PM »
It’s worth trying, let’s see how good the wife’s Dyson really is  :10_2_12:
Offline Ady
Re: Tuff Brake Rub
« Reply #7 on: February 24, 2020, 08:12 PM »
I never used this stuff..
Cherrypicker sent me this link as originally planned on cleaning of set of yellow tuffs . Unfortunately there faded so I don’t think this stuff would work .. going down the wet and dry method with high grade 800 plus paper
https://www.ebay.co.uk/itm/150ml-OZZIES-RECIPIE-BMX-MAG-WHEEL-CLEANER-SKYWAY-SIMPLEX-MOTOMAG-ACS-Etc/133333813436?hash=item1f0b5088bc:g:HuAAAOSwnhdd1Auf
Re: Tuff Brake Rub
« Reply #8 on: February 24, 2020, 08:42 PM »
Nice one Ady, that looks more like what I was thinking. I might give that a go  :daumenhoch:
Re: Tuff Brake Rub
« Reply #9 on: February 25, 2020, 10:44 PM »
When you're at the razor blade stage use one of these style of blade holders or similar :
https://www.amazon.co.uk/Stanley-593Oc-Window-Scraper-590/dp/B0001IWDBK/
Gives you a bit more control of the angle you attack the wheel with so you don't cut any gouges into it   :daumenhoch:
Re: Tuff Brake Rub
« Reply #10 on: February 28, 2020, 02:36 PM »
Thanks, got one of them somewhere  :daumenhoch:
Re: Tuff Brake Rub
« Reply #11 on: February 28, 2020, 03:06 PM »
Yeah I use the one I use for scraping me hob  :LolLolLolLol:
Offline Ady
Re: Tuff Brake Rub
« Reply #12 on: March 10, 2020, 07:16 PM »
Was that Ozzie stuff any good ?  fistblump
Re: Tuff Brake Rub
« Reply #13 on: March 10, 2020, 08:32 PM »
I missed because and somebody else snagged it. I’ve checked again and it’s available so will let you know soon  :daumenhoch:
