976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 11:48 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  New school rear brake
Author Topic: New school rear brake  (Read 8420 times)
Offline kalex
« on: April 24, 2020, 02:51 PM »
I haven't a clue if this is in the right section so please switch it if it needs to.
I've got a new school colony bmx which I've had for a few years but only just started riding on it the last few months.
I only go out on it when I'm with my 11 year old son but I've already broken the brake lever as it just doesn't stop.
There could be a few factors why I only come to a very very steady stop, the std brake pads, seems to be flex in the cable or my 105kg.
Anyway I've been pulling on the lever that hard that I've broken it.
I've got a choice of replacement lever or replace the whole lot, lever, cable and brake.
I don't really want to spend much as I hardly use it but I do want to stop better.
I have been looking at odyssey evo set but just asking if anyone has one if these and would recommend them or any other suggestions.
I only run a rear brake as the forks don't allow front and I also like the lever to be on the left.
Re: New school rear brake
« Reply #1 on: April 24, 2020, 04:28 PM »
Sticky pads are your answer  :daumenhoch:
Decent brake blocks with a decent cable should solve most newschool set-up issues. Ask on here to see if anyone has a decent lever going spare, I use Odyssey Monolevers but haven't got any lying about or I'd send you one  :-\
« Last Edit: April 24, 2020, 05:45 PM by Spen69 »
Offline kalex
« Reply #2 on: April 24, 2020, 07:11 PM »
I did look at the monolever but got side tracked by the evo. It's been tricky as I like the lever to be on the left but some are only available for right hand side.
What pads are you suggesting sticky wise as I know screw all about new bmx stuff
« Reply #3 on: April 24, 2020, 09:49 PM »
Pretty sure they're also made by Odyssey, any decent bike shop will have them 👍
Offline kalex
« Reply #4 on: April 25, 2020, 12:14 PM »
Righty O  :daumenhoch:
« Reply #5 on: April 25, 2020, 04:31 PM »
Make sure you toe them in a bit when you fit them bud, they squeal like a pig otherwise  :coolsmiley:
They have a direction arrow on them as well, so watch that little gem  ;D
Offline kalex
« Reply #6 on: April 26, 2020, 04:02 PM »
Yep I make sure all pads are toe'd  :daumenhoch: but it is a good and valid point as it's a simple one to forget to do.
Offline firedfromthecircus
« Reply #7 on: April 27, 2020, 10:37 PM »
I had a similar issue with my 22.
Fitted some kool-stop pads and a tech-77 lever in l/h flavour. Definite improvement and I can now at least lock the back wheel if I want. No chance I was doing that before! All cost a lot less than an Odyssey Evo 2.5 set-up.
Offline kalex
« Reply #8 on: April 30, 2020, 05:28 PM »
I did look at the tech-77 but I wasn't sure of the quality for some reason.
I haven't done anything yet as been busy in the garden and garage
Offline Bigfrawg
« Reply #9 on: May 01, 2020, 06:58 AM »
I run tech77’s on all my builds with clear pads , usually on an ad990 , I’m a fcuking unit and it stops me just fine .
Offline kalex
« Reply #10 on: May 01, 2020, 06:01 PM »
Your last part of the sentence has me sold  :daumenhoch:
Offline Picklez
« Reply #11 on: May 01, 2020, 06:04 PM »
The last part of that sentence mad me pmsl. Keep up the good humour  :daumenhoch:
