976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 07:17 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing seat clamp - advice
Author Topic: Removing seat clamp - advice  (Read 9675 times)
« on: May 20, 2020, 09:07 AM »
Hi all
I've been busy on a few bikes but this one has me stumped a bit. It has an integrated Seat Clamp, but I hate it and want to get it removed. Was these welded in like this? I notice on the side a DOT, which looks like a spot weld. Any ideas how to remove it? I realise that it won't be painted underneath but I intend to get the frame painted anyway. I don't want to to f**k it up or damage the frame but I just would like to get rid of this clamp. Let me know...
Many thanks
Matt  :daumenhoch:
Offline Taipan
Re: Removing seat clamp - advice
« Reply #1 on: May 20, 2020, 10:18 AM »
I've done a few of these but all I can say is some came off easy and some wont budge for example the ones that worked I was able to Dremel off the spot welds on the back of the clap where the bolt sits and with a bit of force with a screw driver of similar it popped off  :daumenhoch: but a couple of others even after removing the little spot welds they would not budge?  :( so Its a case of try it tentively?  ??? just my experience fella someone may know different?
Offline VOIVOD
« Reply #2 on: May 20, 2020, 10:32 AM »
 :) I`ve removed a few similar clamps-not with any finesse (I used a chisel on the spot welds) and just peeled them off.Did no damage other than what wa sleft of the weld had tro be filed/sanded down  & then used a regular clamp.A Dremel should do a much tidier job .
« Reply #3 on: May 20, 2020, 10:39 AM »
Have you tried twatting it with a hammer?
Offline Clean
« Reply #4 on: May 20, 2020, 10:46 AM »
This!
« Reply #5 on: May 20, 2020, 11:33 AM »
It will come off if you let us bum you.
« Reply #6 on: May 20, 2020, 12:27 PM »
What a group bum again? I'm still recovering from the last one  :surprise:
« Reply #7 on: May 20, 2020, 12:28 PM »
That was my plan, i'm nervous but I will give it a go this evening :daumenhoch:
« Reply #8 on: May 20, 2020, 12:29 PM »
I'm gonna try with a screwdriver first, also a dremel. Thanks for the reply, I'll give it a go this evening  :daumenhoch:
« Reply #9 on: May 20, 2020, 12:30 PM »
Anything you post on this forum, should ALWAYS result in you receiving a bumming.
« Reply #10 on: May 20, 2020, 03:46 PM »
Ok i've done it. But looks like my seat clamp, the vintage one I have just won't fit it.
Bugger... so after a plain vintage style clamp now to fit the size.
The width is: 28mm.
This style...
« Reply #11 on: May 20, 2020, 03:51 PM »
So looks like I need a 31.8mm sized clamp from looking online... that's a big bugger!
Offline vestanpance
  • Bollocks.
« Reply #12 on: May 20, 2020, 04:43 PM »
Is that in MK1 B*rner territory?
I said 'machine, why are we here?'
And it paused and said 'to play video games and drink beer'
Offline kalex
« Reply #13 on: May 20, 2020, 06:47 PM »
I haven't a clue but try looking at vintage road bikes etc also
Offline VOIVOD
« Reply #14 on: May 20, 2020, 07:20 PM »
31.8mm is the most common modern BMX racebike size so sure you`ll find something .A few on th bay for about ?6 apiece:)
« Reply #15 on: May 21, 2020, 09:25 AM »
It really is mate, big fat tube!  :D
« Reply #16 on: May 21, 2020, 09:44 AM »
Yeah, the width of the tube is 28mm or just over, so either 28.6 or 31.8 would be suitable, but finding a battered old clamp like that is difficult, just not been able to find anything yet....
Just not sure if i'm doing the right searches in Ebay?
Offline Taipan
« Reply #17 on: May 21, 2020, 11:11 AM »
does it have to be the Berratta style clamp you pictured or can you use a tuff neck style one?
« Reply #18 on: May 21, 2020, 11:55 AM »
Hi mate, as this is a toy shop bike, ideally a vintage looking clamp and not a tuff neck style.  :daumenhoch:
