976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 07:16 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rust on a painted frame
Author Topic: Rust on a painted frame  (Read 8560 times)
Offline Dredgy73
« on: February 16, 2021, 09:21 PM »
Hi all
What is the best way to remove rust on a painted frame?
I would like to keep it original so do not want to harm the decals....
Coke? Cif of something else?
Thanks
Offline Midschoolfool
Re: Rust on a painted frame
« Reply #1 on: February 17, 2021, 02:12 PM »
Neither.
You want to use CAP (Citric Acid Powder) or OA (Oxalic Acid)
https://www.amazon.co.uk/Citric-Acid-1kg-100-Grade/dp/B00DJI8RA0/ref=sr_1_6?crid=2TD8NNAIWCGUX&dchild=1&keywords=citric+acid+powder&qid=1613571112&sprefix=citric+acid+pow%2Caps%2C160&sr=8-6
Put the parts in a tub, put that in with water. Plenty of tutorials on the net.
Offline Dredgy73
« Reply #2 on: February 18, 2021, 08:59 AM »
Thank you 👍
Offline CustardLips
« Reply #3 on: February 18, 2021, 01:57 PM »
"WWG1WGA"
Offline wildon
« Reply #4 on: February 18, 2021, 02:33 PM »
Oxalic Acid works
Offline Dredgy73
« Reply #5 on: February 24, 2021, 06:18 PM »
How long do you leave it in the bath for. Added more crystals, but after a day not much is going on!
« Reply #6 on: February 28, 2021, 02:23 PM »
I normally put in 1/2 - 1 kg and leave for a day. Wipe over every now and again if you can. You will see it working as the rust spots normally turn yellow.  :)
