976302
crissy_criss
July 01, 2026, 09:01 AM
can someone help me?
Topic: can someone help me? (Read 4607 times)
seizuremania
September 24, 2006, 10:26 PM »
hello everybody
i have recently bought some raleigh mag wheels (5 spoke angled type) but they are both fronts. is there any way i can make one of the wheels a rear wheel ready to fit a free wheel? i havent recieved the wheels yet so i can really give a detailed explanation of what theyre like
thanks
RATTY
Double Flip Whip
Re: can someone help me?
September 24, 2006, 11:52 PM »
When you get the wheels, post a pic of the hub, then we can give you a bit more help!! Oh and welcome to the site
seizuremania
September 25, 2006, 12:03 AM »
thanks
i should be getting the wheels on wednesday
seizuremania
September 25, 2006, 12:07 AM »
woops theyre NOS OGK
i got these pics just so you got a bit of an idea..will post a close up when i get them though
RATTY
Double Flip Whip
September 25, 2006, 12:13 AM »
Not sure if you can, but have a look when they arrive to see if you can remove the hub, and swap it. I have never owned OGks so I cant be sure, sorry, someone on here will know though!!!
seizuremania
September 25, 2006, 12:23 AM »
ok thanks
duncan
September 25, 2006, 01:23 AM »
Hi,
I'm assuming you know for certain they're both fronts?, hard to tell unless you see both sides of the wheels.
From that pic alone they do both look the same.
You'll need to find a rear hub, then see if it'll fit when a front is removed, assuming it isn't molded in.
I'm just guessing here, I don't know their construction, but post more pics on Wednesday and people will chime in
Bob_Acid
Team Admin
BMX Overlord
It's Bronked
September 25, 2006, 01:35 AM »
The only way to do it is to tap a thread for the freewheel into the hub that you have. i know it's possible on alloy hubbed Skyways but they have a lot more meat on them than those do but you never know. it means having the right tools to do the job for starters and with what you have you might be better off saving yourself a lot of hassle and just waiting for the right rear wheel to come up for sale.
seizuremania
September 29, 2006, 11:19 AM »
ok i took some pictures, there not excelent quality though
i really dont mind what i have to do, drilling, cutting, anything
i really do hope something can be done.
also one of the wheels dont turn, the bearings have just frozen.
thanks
oh yeah and each sides on both wheels is identical
Last Edit: September 29, 2006, 11:22 AM by seizuremania
Sanmarcopizza
September 29, 2006, 11:25 AM »
I personally think you can't do it. There isn't enough there to safely put a freewheel on. Even if the material was of the right diameter to receive a freewheel and you were able to cut the thread, there probabaly isn't enough material to safely take a frewheel, bearing in mind it will probably need spacing away from the plastic to allow the frewheel to spin without fouling. Sorry.
seizuremania
September 29, 2006, 11:51 AM »
yaarg ok.
these wheels arent going to be doing jumps and stuff, there really just for show and slow riding.
duncan
Reply #11 on:
September 29, 2006, 12:33 PM »
Both fronts, sorry to hear that.
All you can really do is keep watching Ebay for a rear OGK.
There are freewheel convertors that thread onto mountainbike axles (
such as this link
) but then the convertor+wheel might be too wide to fit in the frame, or the axle might be the wrong diameter to fit through the hub/frame.
Unless you were absolutely sure it would work I wouldn't go to that sort of expense, far cheaper just to get a new wheel.
seizuremania
Reply #12 on:
September 29, 2006, 12:48 PM »
yeah, i'll just look out for a rear one.
seizuremania
Reply #13 on:
September 29, 2006, 01:04 PM »
one wheel is now for sale
http://www.radbmx.co.uk/forum/index.php'topic=19955.0
Andy
Reply #14 on:
September 29, 2006, 01:07 PM »
its been done before ive seen it, cant remeber who did it, ask on v as thats where i read it
seizuremania
Reply #15 on:
September 29, 2006, 01:11 PM »
sorry if this is stupid, but what is v?
duncan
Reply #16 on:
September 29, 2006, 01:30 PM »
vintagebmx, the US BMX site. Go to the forums, then search for 'OGK' or 'convert front to rear' and similar things.
Will maybe take a bit of searching, but if someone's seen a solution..
seizuremania
Reply #17 on:
September 29, 2006, 01:32 PM »
ok thanks alot
seizuremania
Reply #18 on:
September 30, 2006, 09:05 AM »
cant find that guide/conversion anywhere
seizuremania
Reply #19 on:
October 01, 2006, 01:08 PM »
so i cant just drill/cut the wheel up a bit to use this?
http://cgi.ebay.co.uk/NOS-OLDSCHOOL-SKYWAY-REAR-FREEWHEEL-HUB-REPLACEMENT-KIT_W0QQitemZ270035044493QQihZ017QQcategoryZ64644QQssPageNameZWD2VQQrdZ1QQcmdZViewItem
lazychubs
Founding Fathers
BMX Nerd
Reply #20 on:
October 01, 2006, 08:47 PM »
ive got a mini burner rear fingy that you could try just slips on my 16 inch ogk type wheels
pm me ure addy and i will post it to ya
lazychubs
Founding Fathers
BMX Nerd
Reply #21 on:
October 01, 2006, 08:54 PM »
right just tried it on my 20 inch ogk.s wot you have to do is knock the bearing cup out and will have to araldite it in
as its a tad loose but will deffo work as long as there not to much pressure whilst riding lol
or i have a pair of blacks copy's ive just tried to get the rear alloy thing out and is moulded in with the wheel so now the wheel is fecked lol
Last Edit: October 01, 2006, 09:11 PM by Lazychubs
zed4130
Reply #22 on:
October 01, 2006, 09:37 PM »
anything is possible just need the parts for a back wheel ive done sranger things in the past with bikes good luck and welcom this is a great site you will love it.
