976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 01, 2026, 05:40 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  aero reflex seatpost
Author Topic: aero reflex seatpost  (Read 2148 times)
spesh
« on: September 26, 2006, 10:02 PM »
anyone know the size coz ive put a 22.2 mm post in and it seems a bit slack by about a mm
it deos up tight tho but the seat tube pinches up quite a bit  is this right?
daz bmx it!
Re: aero reflex seatpost
« Reply #1 on: September 26, 2006, 10:20 PM »
use a seatpost  shim ;) someone on here will no doubt have one for you :daumenhoch:
duncan
« Reply #2 on: September 26, 2006, 10:40 PM »
Try http://www.billys.co.uk
Depends on whether you have old or newschool frame, different seattube diameters. A lot of shims for sale are for new bikes and too big.
I found a Wald shim on Ebay that took 22.2 down to 21.1, it'd reduce your seattube diameter by ~1mm, but I noticed the seller is no longer registered.
It'll be available elsewhere though, it's a standard sized shim. It has a serial code if you need me to check it.
Edit>> I better mention the coke-can trick, you could make your own shim quite easily.
« Last Edit: September 26, 2006, 10:44 PM by duncan »
spesh
« Reply #3 on: September 27, 2006, 12:12 PM »
the 22.2 seatpost is about 1mm to small compared to the tube ive done the coke can but it still deosnt seem enough
Offline Del
  • Re-living my youth!
« Reply #4 on: September 27, 2006, 12:25 PM »
I think I have a spare shim, pm me if you need one
Offline Rombloke
  • do one
« Reply #5 on: September 27, 2006, 08:10 PM »
piece of coke can.....
Dave
haro, how do you do
spesh
« Reply #6 on: September 27, 2006, 09:39 PM »
Dave
piece of cake man?
