976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 02, 2026, 09:08 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  beartrap headset / mk1 gyro
Author Topic: beartrap headset / mk1 gyro  (Read 2150 times)
jstring
« on: October 10, 2006, 10:28 AM »
I am restoring my childhood bike which i got back from the paint-shop yesterday.  Like an excited kid, i started bolting bits on last night but I have a bit of a problem.  Originally the bike had an old ACS style rotor / spinner but being as they were rubbish and I quite want my bike to be rideable, not just a museum piece, I have opted to fit an old mk1 oddyssey gyro which is still in period (just) but far superior.
Anyway, I fitted the tioga beartrap headset as usual, dropped on the toothed locking washer followed by the upper gyro tabs but when I went to put on the final locking nut of the headset, it was very clear that there wasn't enough thread on the top of the forks to fit it.  If I leave out the toothed washer, it fits fine.
My question is, has anyone else had this problem?  What is the best way around it?  I am thinking
1.  Run with the beartrap and leave out the washer - but i am worried that it will come loose all the time.
2.  Switch to a standard headset - but i am worried that it will come loose all the time!
3.  Can anyone recommend a headset that does not come loose but which is less bulky?
4.  Has anyone ever ground down the toothed locking washer and / or the gyro tabs (both are pretty thick) to make more room and if so was it successful? Did it make the headset weak / the brakes spongy?
5.  Has anyone got anyother suggestions like tapping tabs into the stem - although I don't really want to molest my beautiful GT stem?!
Many questions I know, and it is a long shot that anyone else has even had such a problem with such a combination of parts (hutch trickstar / tioga beartrap / mk1 gyro) but any suggestions would be welcome.  Many thanks.
Jason
Re: beartrap headset / mk1 gyro
« Reply #1 on: October 10, 2006, 10:38 AM »
Ditch the Gyro altogether and just run with the beartrap headset?
Never did like those Gyro thingies but that's just my oppinion  :daumenhoch:
I've never had an old school headset that didn't come loose!  >:(  but then i've never run with a beartrap, are they good? do they stay tight?
« Reply #2 on: October 10, 2006, 11:19 AM »
I got an acs rotor on my redline rl, it works just fine. only problem I have is the stem flexes a bit cos it has to be up high.
jstring
« Reply #3 on: October 10, 2006, 11:40 AM »
Ooops! Didn't mean to rude about the old rotors!  I ran one for years (and still might end up running one!).  And I can't imagine riding a bike without some sort of rotor / gyro, that's just crazy!
I did fancy a bit of an upgrade though.
And yes, in my experience beartrap headsets were infinitely better than other old school headsets and i have had a few.  Only problem is the forks can wear a bit where the toothed washer engages but even then, the general design is better than any others.
« Reply #4 on: October 10, 2006, 11:02 PM »
See if you can find an old G.Sport 1" headset locking ring.  Its a nice little nugget that will lock your headset down and replace your top gyro plate at the same time.  I ran that with a beartrap for years, no worries.
I may still have my one, I'm not sure.  i'll see if I can dig it out if you're interested, let me know  :)
jstring
« Reply #5 on: October 13, 2006, 03:27 PM »
I'm very interested.  Let me know if you can find it and how much you want for it.
