976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 03:27 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Surface rust removal???
Author Topic: Surface rust removal???  (Read 2430 times)
mightynimrod
« on: October 22, 2006, 06:34 PM »
Hi ya fellas,
Whats the best way of removing surface rust from chrome so it doesn't damage the plating????
Steve
Offline Rombloke
  • do one
Re: Surface rust removal???
« Reply #1 on: October 22, 2006, 06:40 PM »
lots here will tell you oxacylic acid.
if its only fine surface rust tho, just use 0000 gauge wire wool and a decent metal polish.
Dave
haro, how do you do
mightynimrod
« Reply #2 on: October 22, 2006, 06:43 PM »
Dave
Nice one Dave, where would i get the acid from (if i needed it) ??
FuNMoNsTeR
« Reply #3 on: October 22, 2006, 07:41 PM »
autosol will shift surface rust too with some elbow grease  ;)
Offline Rombloke
  • do one
« Reply #4 on: October 23, 2006, 06:27 PM »
Dave
believe it or not modern common rust remover is very good, but raw oxacylic acid can be got a most home stores in the form of decking cleaner/wood bleach
Dave
haro, how do you do
mightynimrod
« Reply #5 on: October 23, 2006, 07:06 PM »
Dave
Dave
Cheers Dave  :daumenhoch:
Offline sparky
« Reply #6 on: October 23, 2006, 07:59 PM »
I read foil is also good at cleaning, whether or not I'm not sure.
