976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 01:06 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  SKYWAY - PLASTIC HUBS
Author Topic: SKYWAY - PLASTIC HUBS  (Read 2661 times)
Offline Steve P
« on: November 05, 2006, 12:48 AM »
Has anyone tried to modify Tuffs with plastic hubs and made flange plates like those used on the new CF's
I'd like to adapt something similar to the front Tuff on this . . .
Steve  :daumenhoch:
Offline Rombloke
  • do one
Re: SKYWAY - PLASTIC HUBS
« Reply #1 on: November 05, 2006, 12:53 AM »
yes steve, i breifly tinkered with one before, with not a lot of success, if i had put a bit more effort into it im sure somthing decent would have come from it, i know that muttley mentioned doing this to, its do-able, and i have a pair of red tuffs just like that which would benefit from a nice alloy hub on the front
hehe
Dave
haro, how do you do
Offline Steve P
« Reply #2 on: November 05, 2006, 12:58 AM »
So what did you do Dave . . . modify an original hub flange to fit over the top. I reckon it's easily do-able too  ;)
Steve
Dr Skyway
« Reply #3 on: November 05, 2006, 02:06 PM »
Steve, I reckon it would be pretty simple to do too.
But you will ideally need to recess the five inner spokes so that the hub sits flush with the wheel, then just clamp up with the fixing bolts.
Just out of interest how thick are the inner spokes????
Have had a thought of how to do this before, just waiting for some old rims to arrive from the states then I'll be in my workshop  :D
« Reply #4 on: November 05, 2006, 02:42 PM »
Wasn't there a thread on vbmx that showed how the guy made the gold campy type ones?  I think those ones are glued on using clear silicone sealant and are desgined to cover the plastic "spoke".
gjs
« Reply #5 on: November 05, 2006, 03:32 PM »
I done that with some tuffs,but I didn't have a good enough template for the campy hub,but it does work :)
Offline Steve P
« Reply #6 on: November 05, 2006, 03:43 PM »
I intend to make some thinner plates (with false rivets) that simply stick over the original plastic hub without hacking chunks out of the wheel
It can be done . . . I just need measurements from a spare hub flange  :)
Steve
gjs
« Reply #7 on: November 05, 2006, 03:45 PM »
there is a drawing on vintage of a campy hub somewhere :daumenhoch:
gjs
« Reply #8 on: November 05, 2006, 04:00 PM »
This is my first attempt,shape all wrong,will use this drawing for next time :D
Offline Steve P
« Reply #9 on: November 05, 2006, 04:09 PM »
That looks great for a 1st attempt :daumenhoch:
Steve
