976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 01:07 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  freewheel removing from tuff2
Author Topic: freewheel removing from tuff2  (Read 2578 times)
chrishil1
« on: November 05, 2006, 09:39 AM »
cant get the freewheel off,
I havent got a proper tool,
tried hammering the threaded lip, putting a punch in the two external lug holes and hammering round
even tried welding the cog to the casing and putting the cog in vice and turning the wheel, wont budge.
any suggestions apart from take it bike shop?
Chris  ???
mightynimrod
Re: freewheel removing from tuff2
« Reply #1 on: November 05, 2006, 10:02 AM »
Just nip to halfords and get the proper tool
Or send me the tuffs and in return i'll give you some dollar ;)
weston
« Reply #2 on: November 05, 2006, 10:02 AM »
if you dont have the tool & its stuck tight take it to a bike shop, it will only cost about a fiver & it will save you smashing your wheel to bits
« Reply #3 on: November 05, 2006, 01:47 PM »
post a pict incase its a cassette type and if so
you prob just ruined ya tuffs
selfpreservation
« Reply #4 on: November 05, 2006, 04:07 PM »
take it to the bike shop in case you muller them theyll charge you a fiver
chrishil1
« Reply #5 on: November 05, 2006, 04:15 PM »
going to have to be bike shop, fed up with it.
no its not a cassette type.
Got a atom freewheel which wont budge.
dont think its going to move with a slot in pin type socket, 1 of the slots a little bit chewed. not really bad though
hopefully they will have something that will fit like chain and lock.
something like this
http://cgi.ebay.co.uk/PARK-TOOLS-SR-1-CHAIN-WHIP-FREEWHEEL-REMOVER-NIP_W0QQitemZ180044817831QQihZ008QQcategoryZ109122QQssPageNameZWDVWQQrdZ1QQcmdZViewItem?hash=item180044817831
Chris
selfpreservation
« Reply #6 on: November 05, 2006, 06:11 PM »
if all else fails you can crush it in a vice bassically you take the outer part of the freewheel , the cog if you will havef then grip the inner part in a vice ( not too tight or you will wreck the threads on the wheel) then just turn the wheel anticlockwise and it will come off
Offline phantom photon
« Reply #7 on: November 05, 2006, 06:28 PM »
My local bike shop removes freewheels for free  :daumenhoch: Usually end up buying something while I'm there just so that I don't feel so guilty about using them so much  :LolLolLolLol:
Offline sawzall
« Reply #8 on: November 05, 2006, 06:30 PM »
i welded a 12" bar to freewheel so i didnt move then use bar as lever,heat from welding will also help to free it off :daumenhoch:
« Reply #9 on: November 05, 2006, 07:09 PM »
i have never had a freewheel that wont come off in a vice. and ve had some right twats.
Coastvl
« Reply #10 on: November 06, 2006, 10:09 AM »
Same here. Crush the turd in a vice and spin it off. You are going the right way aren't you??  :uglystupid2:
