976289
Homebrewhero
June 12, 2026, 05:50 PM
Polishing?
Topic: Polishing? (Read 9133 times)
daz bmx it!
Polishing?
July 21, 2005, 06:17 PM »
Ok,I need summat i can attach to a drill or similar,that can be bought easily from B&Q etc, that i can polish chrome with,so my hands want fall off! what do you guys use,where did you get it? and how much? answers on a postcard please!
black rat
Re: Polishing?
July 21, 2005, 07:05 PM »
Another
member left a link to this site recently - has just about everything you could need - with regards to polishing...
http://www.frost.co.uk/productList.asp?catID=27
kdw712
900 Air
Re: Polishing?
July 23, 2005, 12:39 AM »
another option is ebay, i brought a drill complete kit
compounds and mops, brought my 25 year old nickle goose up a treat
but looking at frosts their prices are pretty good
cheers Kev
{ wanted : "Red Haro Handle" brake lever
link to my trade post
motomagII
Re: Polishing?
July 24, 2005, 08:55 AM »
just got a small set on ebay going to have a dabble with the renthal bars myself see how shiny i can get them will post pics when done .
scary_leary
Re: Polishing?
July 26, 2005, 08:22 PM »
you can get good results..
i got these cranks off motomagII
u can see the single arm is badly dented around the spindle hole.
a bit of polishing and they've gone
[attachment deleted by admin]
daz bmx it!
Re: Polishing?
July 26, 2005, 08:25 PM »
So what did you use?
sawzall
540 Air
Re: Polishing?
July 26, 2005, 09:33 PM »
if you havent got access to a polishing mop get your self some production paper as used in bodyshops, using a block where possible rub part down working through the grades ie 180 if part has deep scratches or finer if there are only fine scratches like 240 working down through the grades to 1000 then a polish with a mop in an electric drill or a lot of elbow grease with some autosolv should come up like chrome i have had great results with car and bike parts
motomagII
Re: Polishing?
July 28, 2005, 06:44 PM »
i tried the mops etc in the drill nightmare to do .used brown rough polish then blue smooth polish very hard to get nice finish all round bars after 3 hours gave up .then realised i had to wet and dry scratches etc out first and the polish wont do this .determined to try again though asfter i get some more wet and dry my shop only sold up to 400 grade so need a finer one .
anyone else do this how often/long do you use the mops as mine went black st away is this okay to still use then or do you change for clean ones regular .
sawzall
540 Air
Re: Polishing?
July 28, 2005, 07:17 PM »
hi motomag mops will go black straight away the secret is not to load mop with to much polish the best way is to use little polish often otherwise mop will become clogged up and will cause scratches when final finishing (coloring) you should use a calico mop which is soft cotton just done my esp stem looks like chrome persevere mate it will be worth it in the end
oberonspacefruit
BMX Legend
Hoffman's Love Child
Re: Polishing?
July 28, 2005, 07:22 PM »
yeah, not too much polish on the mop, sholud only take 20 mins, if it gets too clogged use a wire brush to get the polish offa the mop
scary_leary
Re: Polishing?
July 28, 2005, 08:09 PM »
I don’t use the drill any more..
You want a bench polisher with a wheel on either side
Course one for stripping and the other a polisher.
oberonspacefruit
BMX Legend
Re: Polishing?
Reply #11 on:
July 28, 2005, 08:10 PM »
dont get a cheapy one for 12 quid from b&q tho cos they just stop when you try and pu a slight amount of pressure on.....
Polishing?
