Re-chroming
<< < (7/7)
mightynimrod:
One of the admins - Ruler, Billstupp, Rombloke or someone like that.
login_user:
Just sent a pm to Mr BIg   Rombloke :daumenhoch:
stuntmaster:
the problem isn`t always the chromer it the prep work as all chroming is pretty straight forward but if say a tube is rusty or has pittings then it will come out on the new chrome work , so really it up to you to get it cleaned and prepped before chroming ,i spoke to biaggio about this and he said he spends a long time getting stuff polished and cleaned so no marks at all and so that why his chrome work is good as he puts the hours in .
i found a guy that does prep work and stated the same but could not prep frames due to the size of them
lazychubs:
yes its true the prep work is the hardest bit but they didnt even try to polish my frame
as the surface rust was stil there once i got it back
login_user:
--- Quote from: stuntmaster on December 01, 2006, 06:04 PM ---the problem isn`t always the chromer it the prep work as all chroming is pretty straight forward but if say a tube is rusty or has pittings then it will come out on the new chrome work , so really it up to you to get it cleaned and prepped before chroming ,i spoke to biaggio about this and he said he spends a long time getting stuff polished and cleaned so no marks at all and so that why his chrome work is good as he puts the hours in .
--- End quote ---
Absolutely!  But you don't expect to get a bad job from someone that says they will prep it,especially if it's not bad to start with,the first time i got my frame back it was worse then before i gave it to them. :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
