976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 04:59 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  flight question
Author Topic: flight question  (Read 2156 times)
Offline dwain dibbly
flight question
« on: December 12, 2006, 07:04 PM »
does anyone have an exploded view of a twin pinch flight
or any good picks of how it goes together?
also who does decals for the twin pinch (im assuming they are
different to the single pinch ones that vertego do?
Re: flight question
« Reply #1 on: December 12, 2006, 08:27 PM »
I have these, they are photo copy scans, hope they help
Re: flight question
« Reply #2 on: December 12, 2006, 10:46 PM »
still cant figure it out from that?  :-[
this is all i have. is any thing missing?
scottyp
Re: flight question
« Reply #3 on: December 12, 2006, 11:08 PM »
Yes,
. you need a sleeve/spacer to fit on the spindle that goes inbetween the bearings
. a hammer
. a bit of wood
.basically beat one of the bearing cups into the bottom bracket.
.slide the spindle with said spacer/sleeve on(cut to right size) negative space between cups
.beat the other bearing cup into position with spindle and sleeve insitu.
.add any washers to pack the spindle out allowing the crank arms to turn freely without hitting the chainstays.
.put arms and chainwheels on
.tighten up spindle bolts and pinch bolts
.jobs a good un.
ride and enjoy,
scott
Re: flight question
« Reply #4 on: December 12, 2006, 11:50 PM »
dont forget to space the drive arm out so that the chainring is in line with the rear freewheel.
Re: flight question
« Reply #5 on: December 13, 2006, 12:10 AM »
jesus i didnt think it was going to be this complicated ::)
is this not the sleeve/spacer?
Re: flight question
« Reply #6 on: December 13, 2006, 12:21 AM »
The spacer that goes between the bearings is about 4 times as long as that. It sits between the bearings when they are in the frame to stop them crushing together when the crank arms are tightened up. You can use an old seat post or handlebars cut to the right length, but you need to get a good straight, square cut so it sits well against the inside of the bearing.
Coastvl
Re: flight question
« Reply #7 on: December 13, 2006, 11:06 AM »
Rinni sells the sleeves. I think it's the right one. I bought a spindle (complete) and it's perfect. Cheap too.
Re: flight question
« Reply #8 on: December 13, 2006, 11:43 AM »
dont tighten the pinch bolts too much. they are very weak
