976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 06:20 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  3 piece crank question?
Author Topic: 3 piece crank question?  (Read 2223 times)
daz bmx it!
« on: January 04, 2007, 11:02 PM »
I have two drive side crank arms so Can you cut the spider off the drive side crank arm and put it on the other side to make a set? ::) its an alloy one like a suntour or maxi cross?
Re: 3 piece crank question?
« Reply #1 on: January 04, 2007, 11:05 PM »
Think the pedal thread will be wrong
« Reply #2 on: January 04, 2007, 11:13 PM »
it will definately be wrong
unless you fit 2 right hand side pedals
but that would be fruity
you could put a RH spindle in a LH pedal
lot of fanny arsing around though
daz bmx it!
« Reply #3 on: January 04, 2007, 11:14 PM »
I got loadsa pedals ;)
« Reply #4 on: January 04, 2007, 11:20 PM »
get sawing then daz!
daz bmx it!
« Reply #5 on: January 04, 2007, 11:21 PM »
Ah feck it! to much like hard work then :D
