976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 03:48 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  HEAD SET HELP.
Author Topic: HEAD SET HELP.  (Read 3170 times)
HEAD SET HELP.
« on: October 06, 2005, 06:44 PM »
so what the best way to get head set cups out.
and then new back in again.
i've herd they can be a bit of a job without a press.
Re: HEAD SET HELP.
« Reply #1 on: October 06, 2005, 06:47 PM »
screwdriver and hammer to get em out....vice or hefty g clamp to get em in, or threaded bar with plates/nuts  on
scottyp
Re: HEAD SET HELP.
« Reply #2 on: October 06, 2005, 06:54 PM »
vice to get them in and out :)
weston
Re: HEAD SET HELP.
« Reply #3 on: October 06, 2005, 07:16 PM »
try some wood that fits down the inside of the tube & a hammer to knock them out then theres no damage as metal on metal will damage & weaken the cups...(hope you understand what i mean & you not gonna put your own wood down the hole) ;D
Offline ORB
Re: HEAD SET HELP.
« Reply #4 on: October 07, 2005, 10:32 AM »
ORBs Method.
Get an onld big screw driver and slide it through the inside of the frame and bray it with a big hammer, It will fly out no probs.
Get em back in, 2 blocks of wood and a mallet.
(same for BB)
12
Re: HEAD SET HELP.
« Reply #5 on: October 07, 2005, 11:04 AM »
orbs method is best
you'd need to be geoff capes to recreate the amount of force the mallet / wood gives with a vice (let alone a g clamp)
Offline region11
Re: HEAD SET HELP.
« Reply #6 on: October 07, 2005, 11:47 AM »
Hammer and srewdriver has worked fine for me.  Don't use that method on alloy cups tho.
Neil
holeshotter
Re: HEAD SET HELP.
« Reply #7 on: October 09, 2005, 11:57 AM »
Gettin them out svrewdriver but getting them in I made a simple device out of bits and bobs cause I didn't want to hammer about with my flights..
I use it for bottom brackets and headsets. You need a long threaded bolt that has thread al the way down it or nearly all the way. If you imagine a stem bolt but with thread all the way down it. then you need two big washers or bits of metal (bigger than cups you are trying to get into frame) with holes in the size of the bolt to go through the middle. Very simply washer or metal plate on one end slide through headset cup, through head tube, through other cup on other side, put other washer and nut on then tighten. Cups will be in place without damage.
If you want a pic let me know.
