976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 10:28 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  FITTING A ONE PIECE CRANK SET-HOW ?
Author Topic: FITTING A ONE PIECE CRANK SET-HOW ?  (Read 2795 times)
mclarenj
« on: January 11, 2007, 03:43 PM »
Has someone got a guide ? Can someone help ?
Don't know where to start ............. :'(
Re: FITTING A ONE PIECE CRANK SET-HOW ?
« Reply #1 on: January 11, 2007, 03:45 PM »
has your frame got silver cups already fitted in the frame? in the bottom bracket, where the crank will go?
Offline Rombloke
  • do one
« Reply #2 on: January 11, 2007, 04:08 PM »
ok, it goes like this
press cups into bb on the frame
then thread the chainwheel onto the crank, locating the pin on the drive side arm in the slot on the spider/chainwheel
then thread thick washer on to sit against this
followed by cone nut...there is two of these in a bottom bracket kit...only one will fit this thread, as its bigger than the other.
then one of the bearing race's
then theadle the crank through the hole in the bb.
then fit the other bearing race into the open side cup
followed by cone nut(smaller threaded of the two)
then the tabbed washer, aligning the tab in the slot in the thread
finish with the thin lock nut(there may well be two of these, to be tightened against eah other)
oh...dont forget the grease
Dave
haro, how do you do
electobooty
« Reply #3 on: January 11, 2007, 04:19 PM »
Definately do not forget to grease up or it will only cause heartache :daumenhoch:
Also if you need to press the BB cups into the frame  MAKE sure you use a wooden block to protect frame and cups :daumenhoch: :daumenhoch:
Offline kdw712
« Reply #4 on: January 11, 2007, 04:33 PM »
heres a web link to sheldon browns site
might help
http://www.sheldonbrown.com/opc.html
cheers Kev
mclarenj
« Reply #5 on: January 11, 2007, 10:47 PM »
Thanks for all of your responses guys-I salute you all.
I'll post some pictures if and when I get stuck ! Might need a few more pointers......
« Reply #6 on: January 11, 2007, 11:25 PM »
You will need the correct spanners as mole grips and stillsens just chew the nutts up. Trust me on that one :)
Offline Rombloke
  • do one
« Reply #7 on: January 12, 2007, 06:56 PM »
cant beat having your nuts chewed tho bob.....
eh!!!
Dave
haro, how do you do
« Reply #8 on: January 13, 2007, 02:29 AM »
I dunno mate, mine are still a bit tender  :shocked:
