976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 10:37 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  rare bike repaint . . . .
Author Topic: rare bike repaint . . . .  (Read 5383 times)
« on: October 12, 2005, 01:58 PM »
I have a green streetbeat frame.
its NOS. it's a gem
i don't like the green though, so I am gonna respray it.
would it best to: inspector mors the frame to bare metal ~ or ~ sand it up and use the green as a good base for the new paint to stick to?
Re: rare bike repaint . . . .
« Reply #1 on: October 12, 2005, 02:03 PM »
mors every time
« Reply #2 on: October 12, 2005, 02:04 PM »
i'm thinking i wouldnt have to use primer if i left the greenery on there.
« Reply #3 on: October 12, 2005, 02:07 PM »
paint reactions. bad news. if your going down the "i wont have to " route, dont paint it or youl feck it up every time like i do.
« Reply #4 on: October 12, 2005, 02:08 PM »
i was gonna use hammerite (smooth) for the repaint.
what are frames generally painted with?
is it some sythetic shyt?
Offline ORB
« Reply #5 on: October 12, 2005, 02:09 PM »
Did you just use the H word?
12
« Reply #6 on: October 12, 2005, 02:10 PM »
hehehe
whats up with hammerite?
« Reply #7 on: October 12, 2005, 02:12 PM »
aaaaaaaaaaaaaarrrrrrrrrrrrrrrrgh  never use hammerite...its my nemesis...
you always thinh it will be good cos its strong etc.....the amount of things ive messed up with hammerite or smoothrite is beyond counting.
then when the little bubbles in it for, or it wont stick to some miniscule dot of shit, you cant get the bastard off.
use acrilic or cellulose. celli is harder to spray, cos it blooms, but this can be polished when hard.
b an q plasticote is good if you want a simple colour
otherwise acrylic, double concentrate from car shops...not halfords.
« Reply #8 on: October 12, 2005, 02:15 PM »
i seeeee!!!
fair point.
i painted my faze 7 pink using plasticote from b and q.
i will find a car shop that sells rattle cans then.
any online outlets you can think of, save me getting off my cheeks?
« Reply #9 on: October 12, 2005, 02:17 PM »
bms has a good range and has stores up an down the country
autopaint international will probably have a website, and their spraycans are the dogs, lovely wide arc. nice and powerfull and not piss squirty.
make em themselves on the premisis
Offline ORB
« Reply #10 on: October 12, 2005, 02:22 PM »
Indeed.
I painted the bonnet of my last 205 with a tin from there and it was VERY good, but the laquer was not as good as original. But after a bit of work I got it all matched up...
12
« Reply #11 on: October 12, 2005, 02:36 PM »
a good tip for rattle cans is get them hot
put them in a boiled kettle of water (BOILED not boiling)
or on the radiator
or if you plan a paintjob the next day, stick em in the airing cupboard
« Reply #12 on: October 12, 2005, 02:41 PM »
i dont have an airing cupboard.
Offline Rombloke
  • do one
« Reply #13 on: October 12, 2005, 06:19 PM »
you pikey.....no airing cupboard
get it powdered...its the best way to go if you are a bit of a numpty with spraying, i normally get pretty good results using cellulose paint. or missfits craig does a blinding job with the 2k stuff.
remember tho lots of fine coats not a few heavy layers, and cellulose can always be flatted off and polished if the finish isnt too clever....
you could use the original paint as a base but it may be prudent to seal it with a decent base coat sealer after youve keyed the green, however you still need to prime on top of the sealer anyway...but it beats using paint stripper hands down....am i waffleing now....stop
good luck and take your time
Dave
« Last Edit: October 12, 2005, 07:46 PM by Rom Bloke »
haro, how do you do
« Reply #14 on: October 12, 2005, 06:55 PM »
i can spray fine with a spray gun and 2k paint
my dad used to build powerboats, and we had a spray booth
sprayed many a car in there.
powercoating is too expensive for my streetbeat. plus i need more than one colour ;)
more than 2 even ;)
« Reply #15 on: October 12, 2005, 07:19 PM »
so why you askin all the questions then wiseguy................
Offline Rombloke
  • do one
« Reply #16 on: October 12, 2005, 07:48 PM »
glad i waffled on for so long now...lol
Dave
haro, how do you do
« Reply #17 on: October 12, 2005, 07:53 PM »
i dont really know what kind of paint is used on frames generally.
and i'm wondering what you lot'd do in my situation.
with cars its was easy - key the surface then whack the new colour on.
plus i wanted to take a shortcut by not morsing the frame.
wish i still had a spray booth to use.  >:(
dave your tips on spraying are vital for any spraying novice.
also one point of note is that spray can paint takes a full WEEK to harden properly.
weston
« Reply #18 on: October 12, 2005, 08:05 PM »
painting with ease, sand down, primer, sand down smooth(wet & dry), paint(many thin coats,10 mins apart), sand down(wet & dry to a haze), laquer, finished ;D
Chris
« Reply #19 on: October 12, 2005, 08:08 PM »
Halfords mixed colours - ie. get them mix a colour for you - are a nice cellulose with decent cover & a nozzle which gives a nice arc. Worth 10 times the standard pre-mix range, yet less than twice the price.
weston
« Reply #20 on: October 12, 2005, 08:12 PM »
also comes with a booklet on how to paint for people who have never painted before
« Reply #21 on: October 12, 2005, 09:32 PM »
i never knew halfords did this.interesting.
ash
« Reply #22 on: October 13, 2005, 05:41 PM »
i tried nitromorse on a mk 2 burner frame ............didnt touch it !!!!!!
the tin is a couple of years old though or do you need to rub the frame with some corse emery?
