976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 10:53 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  can the cages be taken off on these
Author Topic: can the cages be taken off on these  (Read 2614 times)
LXIX
« on: February 28, 2007, 10:49 AM »
ok ive never seen a set for years and b4 i buy them i need to know if you can swop the cages as i need to anodise them black,looks to me as if its a stud ataching the cages that will need to be drilled out if this is the case how will i get the cages fixed back on? ::) :tickedoff:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=019&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=290086843116&rd=1&rd=1
Re: can the cages be taken off on these
« Reply #1 on: February 28, 2007, 10:56 AM »
Short answer Mark...No. They are attached to the main body from memory
LXIX
« Reply #2 on: February 28, 2007, 10:59 AM »
 :LolLolLolLol: not the answer im looking for ratty ,do you think it would be possable to drill out the studs and retap the hole and fit bolts to suit? who is familur with these shite pedals?
« Reply #3 on: February 28, 2007, 11:03 AM »
Ohhhh, I see. You will have to grind the alloy down without buggering the cages to do it. I would say its possible, but wont they look pony afterwards
LXIX
« Reply #4 on: February 28, 2007, 11:06 AM »
 >:( any body got some black db caged 9/16 pedals
Offline jimwise68
« Reply #5 on: February 28, 2007, 11:12 AM »
Re-annodise and strip off the bits you don't want!
LXIX
« Reply #6 on: February 28, 2007, 11:20 AM »
jim i want all the bits just not red  :idiot2: :LolLolLolLol:
« Reply #7 on: February 28, 2007, 11:46 AM »
I think he ment strip and anno the whole pedal, then strip the unwanted anno off the body :shocked:
LXIX
« Reply #8 on: February 28, 2007, 11:48 AM »
 :shocked:
Offline jimmyp
« Reply #9 on: February 28, 2007, 03:09 PM »
just spray them black with a can, they'll be fine :LolLolLolLol:
Offline Waxintaxin
« Reply #10 on: February 28, 2007, 03:31 PM »
They are riveted on mark
so with some decent metal work kit they can be done, either re anno the cages and rivet them on or as you say retap the hole and screw in with some grub screws
Do able but fiddly
Rich
