976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 07:16 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  applying decals
Author Topic: applying decals  (Read 7509 times)
applying decals
« on: July 23, 2005, 10:00 AM »
right chaps what fluids do you use to apply decals, one of my wifes little jobs this is but she is concerned this time as they are chrome decals so any suggestions will be appreciated
Re: applying decals
« Reply #1 on: July 23, 2005, 10:16 AM »
i put a little bit of soap and water in a desert bowl and apply with a sponge. The soap i use is that Carex hand wash but anything will do. I've used this on both plastic and foil decals.
aditup
Re: applying decals
« Reply #2 on: July 23, 2005, 10:17 AM »
Try up the decal to find the position you are happy with, then use masking tape on one end to hold it there. Then, with masking tape still holding the one end, peel off the backing and apply in small "sweeping" strokes, to eliminate any air pockets. I know peeps will suggest the soapy water method, me no likey. Ad
Offline ORB
Re: applying decals
« Reply #3 on: July 23, 2005, 10:18 AM »
Get one of those spray whingies, I use an empty Window cleaner bottle.
Put one droplet of washing up liquid in the bottom and add warm water.
Make sure frame is clean and dry and free from Llama's (alcahol is gool for this as Llamas dont like booze)
Spray a fine mist of the water onto the area awaiting decals, and apply.
Move the decal into the exact position required and squeegy out as much of the water as you can with a cloth or card or something.
Put bike somewhere warm and dry to set and in about 24 hours you are ready to rock.
ORB
12
Offline Zippy
Re: applying decals
« Reply #4 on: July 23, 2005, 12:39 PM »
I didn't think the soap and water method would work at all. However I tried it and it works a traet.
weston
Re: applying decals
« Reply #5 on: July 23, 2005, 06:38 PM »
i fit window tints for a living & i just use plain old tap water with a touch of baby oil,sometimes washing up liquid but remember to get rid of the excess water with a squigy or something when its in place..
Offline Waxintaxin
Re: applying decals
« Reply #6 on: July 23, 2005, 11:23 PM »
Quad
I add a little fairy to some water in a plate.
and drag the sticky side of decal across the water
you can slip and slide the decal into place and smooth the air and water out
Jobe done
Rich :)
Offline danny silverstreak
Re: applying decals
« Reply #7 on: July 24, 2005, 01:28 AM »
i just whack em on dry and when i get a big air bubble i just pop it with a needle, preparation is not my forte - when i decorate - i spend 1 hr painting and 3 hrs getting paint spots off carpet 8)
The-flying-banana
Re: applying decals
« Reply #8 on: July 24, 2005, 09:08 PM »
 :) are they chrome gt ones by any chance  ???as if they are they wrinkle up  ;)so you should send them too me ;D
Re: applying decals
« Reply #9 on: July 25, 2005, 11:06 AM »
tinkerbell? youd never get the llamas away from her...
Re: applying decals
« Reply #10 on: August 23, 2005, 10:21 PM »
well the wife had a go tonight with some chromes ones and they didnt turn out to bad, little bit one sided, tried the soapy water but didnt really make a difference and yes put shed loads on the frame, I was gonna have a go put my trotters aint no good
steve
Re: applying decals
« Reply #11 on: August 24, 2005, 05:02 PM »
atomiser - plant sprayer, filled to top, with one-yes one! blob of fairy - this is just to break the surface tension of the h2o to stop the water balling up
the method is known as hingeing, when applying masking tape to one end, to aid positioning.
-using another piece at the other end,and then tearing through it, then taking the back off, wetting and re alligning the torn tape.
this method is a must, when applying dry
stiff felt squeegees are available, these will not scratch your new decals, but a duster wrapped around a finger is better on a tube anyway!
steve - the sign worx , in the central london yellow pages.
supplier of mono colour computer cut graphics
chrome gold and chrome silver plus brushed alloy sticky in stock
plus every other colour available
prices from 10 quid plus post
« Last Edit: August 24, 2005, 05:04 PM by steve »
Jazzchimp
Re: applying decals
« Reply #12 on: August 24, 2005, 05:50 PM »
Anyone tried oiling a baby?
