976303
crissy_criss
July 07, 2026, 05:03 PM
Leary Turbo Crank Spindle?
Topic: Leary Turbo Crank Spindle? (Read 2990 times)
FuNMoNsTeR
March 07, 2007, 01:31 PM »
I had this spindle arrive this morning. It was advertised as a Turbo Lite Spindle but the seller says they removed it from a double tubed set of DB cranks, which leads me to believe it is for a Leary Turbo or Early Redline crank. Is this for open bearings? as i can see no mounts for sealed units...... Thanks Guys
Jazzchimp
Re: Leary Turbo Crank Spindle?
March 07, 2007, 02:02 PM »
guess the spindle!
loose ball defo as for the turbo bit... not sure
FuNMoNsTeR
March 07, 2007, 02:13 PM »
I think its the large size. It measures 12mm or 1/2 and inch square on the narrowest end of the taper.
GREMLIN
March 07, 2007, 05:14 PM »
Andy ask bmx-796 about the spindle he has on his turbo. From the looks of his pics he's running a loose ball bottom bracket with his turbo crank set
dj_benice
March 07, 2007, 05:16 PM »
from memory the early 400 flights (sugino) and DB three pieces all had the same square tapered spindle
All the sugino spindles are pictured here
http://www.radbmx.co.uk/forum/index.php'topic=26518.0;topicseen
Last Edit: March 07, 2007, 05:22 PM by dj_benice
digitaltransfer
March 07, 2007, 06:49 PM »
I always thought DB and Redlines were Sealed BB though !!! cant remember seeing anything other than !!
I had a set of profiles, redlines 400 and 401 and they were always sealed BB ?
I remember looking at N restalls DB and his Bros they were always sealed as well !!
But also yes it does look like a loose ball spindle though !
lazychubs
Founding Fathers
BMX Nerd
March 07, 2007, 07:43 PM »
try a normal maxy crank arm on it
if it fits then its a normal lite one
if no fit its turbo one lol
as i got a sealed new school one on my turbolite cranks
Waxintaxin
Team Owner
Cherry Picker
March 07, 2007, 07:44 PM »
looks like a 400 spindle , but i have never seen a DB one lol
certainly loose ball , and most early redlines 400s and 401s were loose balll
sealed redlines were the hadley or the techmatic BBs which were top bannana i belive
bof
March 07, 2007, 09:22 PM »
definitely not a harry leary spindle but is definitely a loose ball spindle I would say.
bmx-796
March 07, 2007, 10:02 PM »
sealed b/b on my harry leary
pkradman
March 07, 2007, 10:33 PM »
looks like a 400 spindle to me .. which in turn is a turbo crank spindle
bmx-796
Reply #11 on:
March 07, 2007, 10:40 PM »
do you want to sell it
Frosty
Reply #12 on:
March 08, 2007, 11:18 AM »
The three spindles for the 400 series sealed (Sugino made) cranks are now on Ratty's thread.
I have not heard of 400's in anything other than a sealed version. Could be the DB TL one, I'll see if I can dig out any pics of those.
FuNMoNsTeR
Reply #13 on:
March 08, 2007, 01:34 PM »
Thanks Guys
