976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 08, 2026, 02:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  top tips wanted on home paint job
Author Topic: top tips wanted on home paint job  (Read 7920 times)
« on: March 09, 2007, 08:05 AM »
i have done a fair few wrattle can jobs and they all sucked rearly
so im gonna try another on a hack ride so not to important
top tips needed .
Re: top tips wanted on home paint job
« Reply #1 on: March 09, 2007, 08:09 AM »
top tip.
warm your room.
put the rattle cans in a washing up bowl of hot water.
dont expect to get it right and shiny for quite a while, just keep layering and layering.
especially round the areas that will get more abuse when you flat it down with wet and dry. ie the dropout edges. Laquer it if you want, i do usually, but paint thats been flatted and polished usually looks good.
leave it for at least 3 days before flatting it.
then t-cut.
« Reply #2 on: March 09, 2007, 08:18 AM »
and dont take it outside with greasy hands and drop it hehe
« Reply #3 on: March 09, 2007, 08:36 AM »
twat.
« Reply #4 on: March 09, 2007, 08:37 AM »
notice i didnt put up the lol sign......heh heh
« Reply #5 on: March 09, 2007, 08:38 AM »
how many coats of laquer do you use,i generaly give it 4 coats but will need to let it harden for longer.
« Reply #6 on: March 09, 2007, 08:41 AM »
well, i usually just buy 2 big cans, and use it all. i dont usually spray the entire frame at once, cos if you do, you always manage to overspray a certain bit and get runs. i do all the hard bits, and leave it, then do the main tubes.
thats the hardest bit, i work on the principle that it can be a bit patchy, cos it will all be flatted smooth.
Flaz
« Reply #7 on: March 09, 2007, 09:17 AM »
A mate of mine told me before you t- cut it get the finest grade wire wool you can get and give it a good rub over this will remove the tiny dust particles you dont get when your in a proper spray cubilce   then t -cut it back so its shiney again then put your decals on, then you protect it
hope this helps dan ?
flaz
« Reply #8 on: March 09, 2007, 09:23 AM »
heat is the key
get your paint warm like phil said - leave the cans on the radiator, or in the airing cupboard for a while. or the hot water trick. either is good.
also get the frame warm too.
lash on as much primer as you can afford, then wet flat that
wet flat it with 400. that'll do. if you go through the primer, put more on then wet flat again.
this will give you a smooth surface for the paint
panel wipe is useful here
put the top coat on in layers
keep it hot
when you have finished put the stuff somewhere warm for at least a week
spray can paint takes 7 days to go hard
« Reply #9 on: March 09, 2007, 09:25 AM »
also, when you are wet flatting dont use just the paper
wrap the paper around a rag. keeps lots of water on the job
stops the paper filling up too quick
if you are dry sanding anything, take the sheet of sandpaper, split it in half
then take that half and fold it into a third of it's size
« Reply #10 on: March 09, 2007, 12:30 PM »
yep, loads of water.......i stand mine in the sink, on a sponge to protect the drops.
sonic-1
« Reply #11 on: March 09, 2007, 12:55 PM »
wouldnt heat the cans to much !!!! room temp works ok . the main thing is the primer coat do it real thick then once dry use p600 wet n dry to flat the primer real smooth then use p800 wet over it then yer ready for paint
hang frame up in nice clean garage get the garage over 20*c  then spray light coat all over give this 10 min to go off  then coat again all over waint another 10 min then yer ready to put thicker coat on n go for the finish
« Reply #12 on: March 09, 2007, 01:55 PM »
I wouldn't advize the '1980's council estate Burner' method, of just sticking the whole bike up against a wall (preferably not your dads garage wall....someone elses) and then just spray as hard as you can.....covering everything in it's path.....Tyres, cranks, seat tube...the lot!   :daumenhoch:
« Reply #13 on: March 09, 2007, 06:38 PM »
thats ok my fruity friend
a nice dry slap coming ure way soon  :P
« Reply #14 on: March 09, 2007, 10:12 PM »
I'd just get SuperbikeDan to powder the damn things  :LolLolLolLol:
Offline superbikedan
« Reply #15 on: March 09, 2007, 11:45 PM »
dan   the top tip i can give you is,
send it to me :coolsmiley: ;D ;D ;D ;D ;D
« Reply #16 on: March 10, 2007, 07:37 AM »
 i no dan but this is only a cheap hack and doesnt warrant a proper job as it will be abused by
kids and probably nicked   ;)  i will get one up to you 1 day.
« Reply #17 on: March 10, 2007, 10:26 AM »
hammerite.
cant beat it lol.
Offline Wayne Ryder
« Reply #18 on: March 10, 2007, 11:01 AM »
hammerite.
cant beat it lol.
Not so fast with the humour, sir.
I got pretty good results with some cans of black Smoothrite. The GT bars I painted in about 1988 haven't need much doing to them since, so I repeated the process on the StreetBeat. Obviously not a mirror-smooth and glossy professional finish, but good enough for a rider.
Offline Gary72
« Reply #19 on: March 10, 2007, 08:59 PM »
With regards to using hot water to warm up the cans, make sure its not too hot as they do go with quite a bang!!!!!!!
Yellow primer over red car in garage,  :10_2_12:blew the small swafega tub the water was in to bits :LolLolLolLol:
Brother was lucky he had just turned away from it as it went off.
Good luck
Offline crazycraig
« Reply #20 on: March 10, 2007, 09:12 PM »
Quote
loving the avatar  ;)
Old School BMX only
Cash is King
« Reply #21 on: March 10, 2007, 09:13 PM »
i have started,the frames being a nightmare to strip,its like concrete  not alots moving it.
« Reply #22 on: March 10, 2007, 09:16 PM »
and not to hot as it dries b4 hitting said frame lol
geeza
« Reply #23 on: March 11, 2007, 08:27 AM »
« Reply #24 on: March 11, 2007, 09:31 AM »
vzi keep forgetting to go on there lol
