976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 08, 2026, 05:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyway Tuffs
Author Topic: Skyway Tuffs  (Read 2198 times)
Offline Faze 3
Skyway Tuffs
« on: March 19, 2007, 02:48 PM »
Hi Fella's
I know I've been asking lots of questions lately but I've another I'm afraid. :-\
Are the hubs (front & back) interchangeable on the later style TuffII's ? If so how do you get um out & where can you buy um?
Basically I have 2 front wheels. Could make a set if I could change one over to a rear ::)
Re: Skyway Tuffs
« Reply #1 on: March 19, 2007, 02:49 PM »
are you on about ali hubbed tuffs?
Re: Skyway Tuffs
« Reply #2 on: March 19, 2007, 03:58 PM »
if alloy, or steel hubs, then yes you can.
might be worth seeing if you can get swap for the entire wheel first though, as they are riveted in.....you can drill them out and refit the hubs with bolts( this is how they are converted to coaster) its an easy job, but they look better with the original rivets.
Offline Faze 3
Re: Skyway Tuffs
« Reply #3 on: March 19, 2007, 04:39 PM »
No I'm ok with the metal hubs, I'm talkin the new type (plastic hub), like the ones thet still make.
adeshere
Re: Skyway Tuffs
« Reply #4 on: March 20, 2007, 12:16 AM »
I believe they are different sizes.
You definetly cannot swap over a coaster hub as its a lot bigger
check out www.coloredtuffs.com for some pics
Offline Faze 3
Re: Skyway Tuffs
« Reply #5 on: March 21, 2007, 01:21 PM »
The diameter of the internal hub space (the metal part) seems to be the same front and back.
Anybody know how to get the hubs out?
Ps. I'm talking new type skyways tuffII's.
Re: Skyway Tuffs
« Reply #6 on: March 22, 2007, 08:28 AM »
you cant.
if your talking about the "new" type plasic hubs......I emailed skyway, and they replied quite quickly saying that they cant be removed without destroying the wheel.
i asked them this because i was trying to butcher up a left hand drive skyway.
Offline Faze 3
Re: Skyway Tuffs
« Reply #7 on: March 22, 2007, 08:40 AM »
shit :P
