976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 08, 2026, 10:47 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  New Skool Headset !?!
Author Topic: New Skool Headset !?!  (Read 4055 times)
Offline Stace
« on: March 24, 2007, 11:54 AM »
Looks obvious but I'm being a bit careful  :LolLolLolLol:
The isn't any bearings in the top so do I just grease up??
Installation instructions very much appreciated?  & How do I fit the cups without fekin up the frame?
Ta
Stace  :daumenhoch:
Re: New Skool Headset !?!
« Reply #1 on: March 24, 2007, 12:02 PM »
there should be bearings in the top mate!
just thwack the cups in
Offline Dingobmxer
« Reply #2 on: March 24, 2007, 12:04 PM »
Stace, d is the top cartrdge bearing
Take the frame and headset to a shop and get them to fit it, they have proper tools to press the cups in and seat the bottom race on the fork crown
 :) DINGO :)
« Reply #3 on: March 24, 2007, 12:06 PM »
hammer and block of wood are the tools you need
« Reply #4 on: March 24, 2007, 12:45 PM »
lol i dont even use the wood.
just smash it  ;D.
spinmaster
« Reply #5 on: March 24, 2007, 01:09 PM »
d is the bearing
Offline Moose
« Reply #6 on: March 24, 2007, 02:40 PM »
As everyone has pointed out D is the top bearing (sealed cartridge type), you should also have a set of angular contact needle rollers for the bottom (F) and there should be a seal for the crown race (G).
The crown race on those Sky Pilots can be a bugger to fit careful you don't break it or it won't seal properly. I took my last one to my local shop and they let me use the correct tool to fit it myself (nice chaps).
Offline Stace
« Reply #7 on: March 24, 2007, 05:55 PM »
Thanks guys,
Gonna take it in and get someone to do it !
Offline Dingobmxer
« Reply #8 on: March 25, 2007, 07:36 AM »
just smash it  ;D.
Rough gits  :LolLolLolLol:
How it SHOULD be done:-
first ream and face the headtube to make it all nice and square,
then press in the cups
after determining the correct length cut he steerer down
then grease and pop together and it will run smooth and last longer :daumenhoch:
 :) DINGO :)
zed4130
« Reply #9 on: March 25, 2007, 10:21 AM »
wow there is a tool  ::) i just use a hammer  :daumenhoch:
« Reply #10 on: March 25, 2007, 10:53 AM »
over engineering or what
Offline Stace
« Reply #11 on: March 25, 2007, 12:11 PM »
All Done !
I've now found a little rubber washer but not sure where it fell out of !!
Offline Moose
« Reply #12 on: March 25, 2007, 02:55 PM »
How small? Is it a rubber seal/washer for the allen bolt?
Offline Stace
« Reply #13 on: March 25, 2007, 04:34 PM »
Same size as the crown race.
Is that the seal you were referring to ???
Offline Dingobmxer
« Reply #14 on: March 25, 2007, 06:17 PM »
Nice setup there Dingo  :4_17_5:
Bru  :daumenhoch:
its my mates shop I use Bru  8)
 :) DINGO :)
Offline Moose
« Reply #15 on: March 25, 2007, 07:10 PM »
Probably. It should fit into the recess that's on the crown race :daumenhoch:
