976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 09, 2026, 12:30 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  HELP ! Profile Crank Install - Poxy Fekin Thing !!!
Author Topic: HELP ! Profile Crank Install - Poxy Fekin Thing !!!  (Read 2765 times)
Offline Stace
« on: April 03, 2007, 10:33 PM »
Guys,
Please help  >:(  >:(   New Profile Race Crank 180 RHD.
Got the instructions and have followed them with no problem until now !  Putting on the 'other' crank arm and have tightened using the crank tool.  Well it won't go any further and it looks like this !
Also got these to nut things in the box but they aren't mentioned in the instructions !!
Haven't fek'd Brand Spanking Profiles have I?  :'(
Ta
Stace  :daumenhoch:
Re: HELP ! Profile Crank Install - Poxy Fekin Thing !!!
« Reply #1 on: April 03, 2007, 10:37 PM »
You should just use the bolt now to pull it right in, the crank tool only starts them.
Offline billstup
« Reply #2 on: April 03, 2007, 10:44 PM »
Use the spare washers that you have and put them on to the crank tool so that it will pull the crank on more, then use the bolt for the rest.
The nut look like they`re axle nuts and have nothing to do with the cranks  :daumenhoch:
Offline diesel
« Reply #3 on: April 03, 2007, 11:07 PM »
WACK EM with a BIG hammer... lol
did you greese them up first?
Thoes splines are tight to get on, but a little greese helps a lot.
bof
« Reply #4 on: April 03, 2007, 11:36 PM »
DONT HIT THEM!! ffs.It loooks to me that you may have to many washers on the drive side if there is plenty of clearence between the crank arm and frame then take some off, I imagine that as it is now the chain line  may be out a little, as the others have said you should be able to pull on the non drive side arm on with the bolts, but make sure the drive side of the axle is pulled all the way through.
Another thought is what size chainring is that and have you tried your brakes on the frame, with the chain on just a thought but it might not fit, if the chainwheel is to small the chain will hit the brake, just something to bear ihn mind. :)
Offline Stace
« Reply #5 on: April 04, 2007, 07:35 AM »
Bof,
The washers are set to what was instructed in the manual.  According to the manufacturer, the frame will take 25/9 so I should be cool with the brakes!
Thanks Gents, I'll have another go tonight, Just wanna ride the poxy thing  >:(
« Reply #6 on: April 04, 2007, 11:04 AM »
i had this the other day when i fitted my set i got off andy.
i just gave em a good ole bash with the lump hammer to get them on level.
they are well tight though.
what sort of rear brake you using on that with so low a front sprocket.
mine just catches with a 36 that looks way smaller.
Offline Stace
« Reply #7 on: April 04, 2007, 11:20 AM »
Its a federal frame that will apparently be fine with 25/9 gearing.  I've bought a fly brake.........
.......You've now got me panicking about that  :LolLolLolLol:
Offline Rombloke
  • do one
« Reply #8 on: April 04, 2007, 04:14 PM »
get some hop up washers, they look way better than those spacers, and do the same job
like this...looky see
Dave
haro, how do you do
« Reply #9 on: April 04, 2007, 06:47 PM »
Dave
They look good, are you running profiles and do you know if the hop-up kits fit Redline Flights?
Marty
« Reply #10 on: April 04, 2007, 06:55 PM »
 ure gonna have to run a fly brake to clear the chain
os somit thinner than that
« Reply #11 on: April 04, 2007, 08:09 PM »
good luck with the brake then.
i'd be interested to see how it goes with the fly brake as i would'nt mind going smaller chain wheel on mine.
Quote
where they from then.
i got about 4 big ole washers on my profiles.
Offline Stace
« Reply #12 on: April 04, 2007, 09:24 PM »
Crank fitted ..................... THANK FEK FOR THAT  :buck2:
Cheers Guys!
Stace  :daumenhoch:
« Reply #13 on: April 04, 2007, 09:56 PM »
alans or custom riders for ya hop up kits
