976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 14, 2026, 08:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Crank Problems
Author Topic: Crank Problems  (Read 2333 times)
modpimp
Crank Problems
« on: April 21, 2007, 04:49 PM »
Hello! could someone on here help me with my Sugino CT 3 piece crank i have just fitted. The problem is, i have got the crank on my frame and it looks fine and turns fine, but there is slight movement from side to side which is really annoying me as whatever i try to do i can't resolve the problem. If i tighten up the nuts on the one side then it pulls the chainwheel in closer up tight to the frame and then the crank then makes a noise while turning as the chainwheel rubs against the frame. If i loosen the nuts then the crank will move even more from side to side which i don't want. I have got the crank in the perfect position but it moves if you push or pull it. Is this normal and will it be ok once the chain is in place to stop it moving. Even better still if there is someone in Birmingham who could come and have a look at then that would be great. Cheers !
Re: Crank Problems
« Reply #1 on: April 21, 2007, 04:52 PM »
fit some spacer washers .
Re: Crank Problems
« Reply #2 on: April 21, 2007, 05:29 PM »
It sounds as though the axle is offset too much, in the wrong way round or its too narrow.  Washers might not help Dan as the crank won't bite on the axle so it will stay loose.  How does the other side look, is there a lot of clearance between the non drive crank and the chain stay?
Offline HUTCHMAN
Re: Crank Problems
« Reply #3 on: April 24, 2007, 09:31 AM »
sorry if this is a dumb question,but have you got the lock nut on the left(non drive side?)
Re: Crank Problems
« Reply #4 on: April 24, 2007, 09:35 AM »
Try and get some pictures up mate......might help the guys to see whats wrong?  :daumenhoch:
Re: Crank Problems
« Reply #5 on: April 24, 2007, 10:30 AM »
well, i think it all got too much for him.
zed4130
Re: Crank Problems
« Reply #6 on: April 24, 2007, 10:32 AM »
were's he gone ?  :LolLolLolLol:
Re: Crank Problems
« Reply #7 on: April 24, 2007, 10:42 AM »
Probably BMX boy 13 under a diferent name  :idiot2:
zed4130
Re: Crank Problems
« Reply #8 on: April 24, 2007, 10:50 AM »
 :LolLolLolLol:  :D
