976305
AntYeo1
July 15, 2026, 07:43 AM
BB advice
Topic: BB advice (Read 1347 times)
Dark Diggler
Berm Worm
BB advice
May 04, 2007, 06:42 AM »
I am about to embark on building a bike with a euro bb, my donor has a us running profiles, I have looked and the euro bb's start at about £20, do I have to get a profile one or will the oddy or the S&M one be as good or is there one you would recommend ?(have you got one spare
) Also is the euro kit all I need to get cracking are there other bits required?
Help always appreciated
Dark Diggler
Berm Worm
Re: BB advice
May 04, 2007, 06:06 PM »
Any help
BrianP
Cherry Picker
Re: BB advice
May 04, 2007, 06:11 PM »
any euro bb to suit a 19mm spindle should be fine, 94.
(so long as you're running the regular profile racing cranks and not the ss cranks.)
sorry tho, only got a 22mm set here.
brian.
Dark Diggler
Berm Worm
Re: BB advice
May 04, 2007, 06:45 PM »
Cheers Brian, but how can I tell if they are ss? (scuse the ignorance, but you may remember sending me a pdf for my first profile install, I am no expert in things profile
BrianP
Cherry Picker
Re: BB advice
May 04, 2007, 06:58 PM »
LOL, oh yeah I remember now!
You well?
The basic diff between the two different sets is the size of the arms and the spindle (all extra beefy on the SS - 22.2mm spindle)
can you give me the number on the rubber seal on ur US bearings and I could tell you the bearing size and therefore your spindle size?
Or if you've got a spare brake lever there that isn't hinged, slip it over the spindle. It'll be real loose on a 19mm one, or a pretty close fit on a SS one.
Bp.
Dark Diggler
Berm Worm
Re: BB advice
May 04, 2007, 07:43 PM »
Just measured the spindle-19 mm , the cranks are still on the donor as the new frame has not arrived yet, will I need a tool to remove the arms, they seem a bit..well...Stuck
Nice one Brian
Simon
BB advice
