976305 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 16, 2026, 04:09 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  primo powerbite creaking problem
Author Topic: primo powerbite creaking problem  (Read 4280 times)
therock
« on: May 13, 2007, 03:32 PM »
when i set off , and put pressure on each crank arm when  the each  arm reaches the bottom it creaks really bad and its doing my head in . any idea s .
zed4130
Re: primo powerbite creaking problem
« Reply #1 on: May 13, 2007, 03:34 PM »
have you got some grease on the arms
« Reply #2 on: May 13, 2007, 03:36 PM »
first check bearings and cups are located snug in bb.
then loosen crank arms a tad,then re try.
also check chainring is not bent or of line
and a tad of grease on spindle
Offline Moose
« Reply #3 on: May 13, 2007, 03:56 PM »
I had the same problem on a set of New School flight cranks. I stripped them down 3 times (including bearings and cups) and regreased them before putting them back together, each time the creaking never went away.
Stripped them off completely and put them on a different frame, no creaking what-so-ever   :-\
Anyway, try stripping and re-greasing. Should work, if it doesn't you'll have to live with it I'm afraid  :(
« Reply #4 on: May 13, 2007, 03:58 PM »
last summer i rode 32 of my bikes and they all creaked,then i found out it was me creaking.   :LolLolLolLol:
therock
« Reply #5 on: May 13, 2007, 03:59 PM »
mmmmm thanks for the help guys will try the grease thing out cos its winding me up big time :tickedoff:
therock
« Reply #6 on: May 13, 2007, 04:01 PM »
id creak if i  had to ride 32 bikes . my god you must ahve a hell of a garage . ha . one more thing to do this work on my bike i want a bike repair stand . were can i get one at a good price .
« Reply #7 on: May 13, 2007, 04:02 PM »
ebay
or even argos extra
Lazarou
« Reply #8 on: May 13, 2007, 04:09 PM »
You could also check the frame around the BB.
« Reply #9 on: May 13, 2007, 04:17 PM »
you can always make shore your your bearings have no play in them.
and you dont have a tight spot on your chain
bof
« Reply #10 on: May 13, 2007, 04:53 PM »
Primos are a pain in the arse for creaking, when they start it is hard to stop. If they are old and used you might not be able to stop it. But Iwouldnt put grease on the square shaft but clean the square shaft and square crank hole with a degreaser making sure they are spotless then put them back together, the only grease I would use is a bit on each thread to help cinch them up nice and tight. Tighten up the end bolts first then tighten up the clampbolts second, This might help but if they ar old and worn you may never stop it.
Offline Rombloke
  • do one
« Reply #11 on: May 13, 2007, 05:18 PM »
any metal mating surfaces that meet will req' a little copper slip grease or they will creak.
every set of three piece cranks ive owned creaked unless they were lubed
Ta
Dave
haro, how do you do
« Reply #12 on: May 13, 2007, 07:20 PM »
Yip.  Coppergrease all over the shop, jobs a good un.   :daumenhoch:
Although, I do know that if Powerbites have ever been run a little loose in their lifetime they do tend to creak thereafter and it's bloody hard to shut em up..
Offline SteveG
« Reply #13 on: May 13, 2007, 07:58 PM »
I had a sealed bottom bracket for my bike and I'm pretty sure that the creaking it made was the bearings in the cups.  I think it was a Tioga one and wasn't brilliantly made. The bearings really needed to be a light push fit in the cups but they fell in.
I got fed up with it in the end and went back to a normal one.
« Reply #14 on: May 13, 2007, 09:38 PM »
That sounds likely.  All that leverage could easily creat some noise   :daumenhoch:
Offline Stodgy
    • RADBMX Shop
« Reply #15 on: May 14, 2007, 11:08 AM »
Take off each arm individually:
- coppergrease and grease it up
- move it on 90 degrees
- tighten down the centre bolt
- then tighten the pinch bolts
- then loosen the centre bolt again
- then tighten down the pinch bolts again
- then the centre bolt again.
Should be sorted!
motomagII
« Reply #16 on: May 15, 2007, 07:38 AM »
mine are brand new ad right arm creaks like fook .annoying it is
Offline Stodgy
    • RADBMX Shop
« Reply #17 on: May 15, 2007, 10:00 AM »
Try the above Greg...never had a problem with Powerbites or Hollowbites creaking...
