976308 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 17, 2026, 11:54 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  headset problem raceface deus headset
Author Topic: headset problem raceface deus headset  (Read 2112 times)
« on: May 18, 2007, 05:41 PM »
i have just took a headset of a bike,affixed it to another  now it move back and forth.
the headset is a raceface deus   i cant see why it moves.
has anyone got a diagram as i could have it assembled wrong.
ronnie360
Re: headset problem raceface deus headset
« Reply #1 on: May 18, 2007, 06:09 PM »
harris sounds like you got your self a cameo thing going on in your shed
back and forth  :LolLolLolLol:
« Reply #2 on: May 18, 2007, 07:18 PM »
Does it have a pressure washer between the forks and the top race?  if so you just need to clamp down on it with the star spangly doofer and the stem, takes a while but you should be able to get enough pressure on to tighten it up, if not ut one or two spacers between the top race and stem and then tighten it up  :daumenhoch:
« Reply #3 on: May 18, 2007, 07:45 PM »
no the problem is the bearings i think and what place they sit in.they are floating bearings
they dont touch the inside of the bearing cups  like a 1"   the bearings seem to small.
« Reply #4 on: May 18, 2007, 07:58 PM »
« Reply #5 on: May 19, 2007, 10:09 AM »
problem solved   :uglystupid2:
as i knocked the top bearings out with a 22mm socket.
i looked this morn at a socket on the floor,it was wearing a chrome skirt  lol
it was the bearing retainer  that locks it all together    :4_17_5:
« Reply #6 on: May 19, 2007, 11:05 AM »
Glad you got it sorted mate  :daumenhoch:
« Reply #7 on: May 19, 2007, 11:19 AM »
me to mate thanks for the link  ive now serviced it as instruction   :)
its a quality headset so didnt want to bin it.
« Reply #8 on: May 19, 2007, 11:25 AM »
too right mate......they don't make too many bad things do Race Face  :daumenhoch:
