How To Bleach White SkyWays/Mags
<< < (3/3)
Rombloke:
top quality bleach is the way to go...or if you use cheap bleach leave it for a few days unopened to reduce....it makes it stronger
Dave
OldSkoolbmxs:
Top tips there,The pictures help alot  ;)
Flake:
2 Fresh top tip.     Just bleached my tuffs as your instructions and it has taken 20 years off them.
My tip off the day is to cover the alloy hubs in greese this stops the bleach attacking them  :)
[attachment deleted by admin]
Superkav:
Spot on with the bleaching guys except for one thing.  Cheap Tesco/Asda/Morrisons thin bleach is just as strong as thick Domestos and for 29p a bottle you can afford to buy 10 or more. Good tip on the grease to protect the alloy hub :)
madall:
I have tried this in the past and the rear wheel came out a bit yellow so hit it with domestos straight to retain the off white discolour, I found the best way is to use Jif(Cif) as its now called and rub the hell out of them or even better get the Ball & Chain to do it for you while you watch the Footie
Navigation
[0] Message Index
[*] Previous page
Go to full version
