976309 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 17, 2026, 04:59 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Measuring chainwheels / spiders
Author Topic: Measuring chainwheels / spiders  (Read 2135 times)
highrisedrifter
« on: May 27, 2007, 01:24 AM »
Hi there
I recently bought a chainring and a spider to go wth it. However, it seems that the diameter of the spider is too big for the chainring
Can anyone tell me from where to where they are both measured, so that I don't make the same mistake again, please?
Thanks
HRD
Re: Measuring chainwheels / spiders
« Reply #1 on: May 27, 2007, 01:27 AM »
I believe that you measure from one hole to the second hole along, almost diagonally if that makes sense  :daumenhoch:
What you have there is a Sugino Ring with a Takagi spider  :daumenhoch:
Coastvl
« Reply #2 on: May 27, 2007, 01:31 AM »
Shimano, Takagi and Sugino +whatever else are different spacings obviously.
The Takagi and Shimano sprockets are noticably bigger than the sugino and some others. I can't tell you how to measure them but they are very noticable when you look at them. Your sprocket looks like a Sugino size and the spider is a Takagi.
Most people use the names to distinguish the sizes.
« Reply #3 on: May 27, 2007, 01:34 AM »
Sugino use 110mm bcd and Takagi 130mm bcd  :daumenhoch:
Updated to 130mm as per the Taffy Geordie  :LolLolLolLol:
« Last Edit: May 27, 2007, 01:45 AM by MartyC »
mark 2
« Reply #4 on: May 27, 2007, 01:36 AM »
Damien, what you do is......it's called the bolt circle dimension. It's as if there is an imaginary circle running through the centre of the holes and you measure it across. On the chainring you've got in the picture it's 110mm but the spiders 130mm. Sugino's and Suntour chainrings are 110mm, Takagi, Tioga and Shimano are 130mm, some have both like Tuf Neck's.......
highrisedrifter
« Reply #5 on: May 27, 2007, 01:40 AM »
Thanks for the help everyone, with the possibly exception of the non sequitur from 69 there.  ;D
So the chainring I have is 110mm and the spider is 130mm.
It makes sense now. Many thanks.
HRD
69
« Reply #6 on: May 27, 2007, 01:53 AM »
old skool,do the monster stomp
highrisedrifter
« Reply #7 on: May 27, 2007, 02:07 AM »
In the quiet words of the Virgin Mary... come again?
69
« Reply #8 on: May 27, 2007, 02:09 AM »
LIKE A BAD SMELL
« Reply #9 on: May 27, 2007, 12:12 PM »
lucy did ask me if the spider would fit and said yeah as didnt know they came in two sizes
highrisedrifter
« Reply #10 on: May 27, 2007, 05:52 PM »
No worries mate. I need another one anyway for another build so it's not a problem.  :daumenhoch:
HRD
