creaking crank
SteveG:
Dunno what the pedals are like but winder if it could be the bearing cups moving. With something like a DX that are alloy the hardened cups are pressed in. If all else fails might be worth getting some spray grease or oil into any gaps, and the repack the bearings normally.
Dark Diggler:
Also could be the chain, slacken your wheels and set up the chain tension again(try this if all the above advice fails), failing that sell me the Dk for £50... everyones a winner :daumenhoch:
Trev:
--- Quote from: 94 performer on June 12, 2007, 06:01 PM ---Also could be the chain, slacken your wheels and set up the chain tension again(try this if all the above advice fails), failing that sell me the Dk for £50... everyones a winner :daumenhoch:
--- End quote ---
then once you've sold the DK, come and see me about getting a "Proper" bike.... ::)
crazy foool:
try tightening the cranks, that usualy helps ::)
animal:
Had this recently and it was 2 things , first was a damaged and loose hub cone, second was loose bearings in my suntour pedals.
Cheers Steve
Navigation
[0] Message Index
[*] Previous page
Go to full version
