976309
Darbs
July 19, 2026, 01:10 AM
front brake cable?
Topic: front brake cable? (Read 2323 times)
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
front brake cable?
June 19, 2007, 01:01 PM »
right....i have fitted a new AD990 on the front of my bike, it works well but i used an old cable which was stretched more than big daddies leotard!!
so can i just use any old type of brake cable (clarks from Halfords) or is there a type i should be looking at??
Thanks in advance
BrianP
Cherry Picker
Re: front brake cable?
June 19, 2007, 01:22 PM »
Easy! Easy! Easy!
Hi Pickle,
You can use pretty much any cable if it's well lubed, but I'd go for one of the many slic cables out there (oddy, animal, etc).
No need for the linear slic type, just the regular type is well suitable.
Bp.
pickle
Site Supporter
My life is Radbmx
June 19, 2007, 01:25 PM »
cheers me old shiner!
June 19, 2007, 01:26 PM »
Linear cables dont tend to work that well on a "potts bolt"ed front cable cos they dont bend as well as a coiled cable. I have got a linear one on my front brake. It pulled fine, and it dead smooth but its always rubbing on the front tyre cos I cant bend it enough for it to clear.
pickle
Site Supporter
My life is Radbmx
June 19, 2007, 01:29 PM »
the housing is pretty much brand new as it had a Pots Mod caliper brake, so i just used the outer cable from that......it's just a nice new cable i need me thinks
MeddlE
June 27, 2007, 12:12 PM »
Odyssey Slic Linear, the A Bike ones are rubbish.
BrianP
Cherry Picker
June 27, 2007, 12:22 PM »
don't worry about it being a linear for the front, ain't necessary. regular slic is fine.
Quote from: MeddlE on June 27, 2007, 12:12 PM
aw cack, guess what i just ordered for a rear brake...
Bp.
MeddlE
June 27, 2007, 12:27 PM »
I ran one (A Bike) on my front brake for a short while as there were supply problems with Oddyssey, piss-poor. Local shop finally got some Odyssey back in and I swapped it over, no brake pad adjustment just replacing the cable. Front brake is spot-on now.
Oh, and the slic linear is more for the front than the rear as it can take tighter turns without binding. I use them for both though.
crazy foool
June 27, 2007, 08:59 PM »
the lin slicks better for both as you can bar spin or tailwhip with out your brake binding
front brake cable?
