976309 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 21, 2026, 09:15 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  stripping powder coating
Author Topic: stripping powder coating  (Read 2172 times)
little7251
« on: July 06, 2007, 09:56 AM »
as the title says any ideas how to do this do i use normal paint stripper or what help!! :daumenhoch: :4_17_5: :Great_Britain:
Re: stripping powder coating
« Reply #1 on: July 06, 2007, 10:58 AM »
nitromors will do it.
but not anywhere near as fast as it does on rattle can paint.
it's a long job
if it's just a set of forks, then plod on. but a whole frameset? i'd leave it on. spray over it.
little7251
« Reply #2 on: July 06, 2007, 11:03 AM »
can superbike dan coat over it thats the question ?? cheers matey  :daumenhoch: :4_17_5: :Great_Britain:
« Reply #3 on: July 06, 2007, 11:10 AM »
should be able to
as long as it's flat
powder usually goes over anything!!
if he doesn't like to powder over powder, chances are he will have a good method up his sleeve on how to get it stripped
« Reply #4 on: July 06, 2007, 03:22 PM »
Shot blast................................................................
season.....................................................................
DONE  :daumenhoch:
little7251
« Reply #5 on: July 06, 2007, 03:25 PM »
man i tried nitro moors its going to take a while lucky i'm patient :daumenhoch: :4_17_5: :Great_Britain:
rarman1
« Reply #6 on: July 06, 2007, 05:42 PM »
have a chat with dan about it mate,
it took me ages to strip my frames and dan needed to sand blast them anyway as there was still bits of paint in the welds and nooks & cranies,
dans a top bloke i'm sure he wont mind you asking him ;)
« Reply #7 on: July 06, 2007, 06:01 PM »
With powder coat you can super-heat it or acid dip - I'm pretty certain Dan can do both so deffo worth dropping him a line  :daumenhoch:
Offline Dingobmxer
« Reply #8 on: July 06, 2007, 06:28 PM »
Dan has an acid dip tank,
I just send him my old tatty stuff and it comes back stunning  :smitten:  :smitten:  :smitten:
 :) DINGO :)
Offline superbikedan
« Reply #9 on: July 06, 2007, 07:41 PM »
ok guys  the answer to the questions,
yes i can powder over the original coat but don't like to as you loose definition in the
welds,  serial numbers ect,
acid strip is good but i find it lifts powder really quick but two pack takes ages :)
and shotblast is the best way but only fine shot ;)
and finally  i can sort out all three :coolsmiley:
little7251
« Reply #10 on: July 06, 2007, 08:35 PM »
hi dan firstly i don' t know the paint code could u get a close match and secondly how much would it be for u to blast the frame and coat it cheers (steve) :daumenhoch: :4_17_5: :Great_Britain:
