976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 08:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  headset help again
Author Topic: headset help again  (Read 2282 times)
weston
headset help again
« on: November 11, 2005, 06:02 PM »
i bought a 1" threaded headset for my old school build, when ive fit it on theres a small gap where the locknut cant reach the tightener, will putting a gyro on solve this gap problem?????
Re: headset help again
« Reply #1 on: November 11, 2005, 06:05 PM »
probably. or a 1" washer. which i have got if u need it.
Offline Rombloke
  • do one
« Reply #2 on: November 11, 2005, 07:38 PM »
when phil says 1" washer he doesnt mean  1" high....
just in case
Dave
haro, how do you do
« Reply #3 on: November 11, 2005, 07:44 PM »
hmm.........is my one inch high washer no good then?
Offline Rombloke
  • do one
« Reply #4 on: November 11, 2005, 07:53 PM »
not if you want your stem not to snap.....which is why in my opinion, you shouldnt fit rotors to 1'' forks.....stems get snaptasticly high when they are installed
Dave
haro, how do you do
« Reply #5 on: November 11, 2005, 07:54 PM »
snaptastic. nice.
« Reply #6 on: November 11, 2005, 08:47 PM »
you could file down the top few threads off your forks
do this with the big threaded headset bit screwed down - then you can wind it up to clean the threads
« Reply #7 on: November 12, 2005, 12:27 AM »
the diamond back ones you get from halfords all seem to do this.i took a couple of threads off the forks with an axe saw. seems to have done the job  ;).
motomagII
« Reply #8 on: November 12, 2005, 08:18 AM »
axe saw fork chopping sounds good .small washer or 2 is my usual route though .
Offline Rombloke
  • do one
« Reply #9 on: November 12, 2005, 09:28 AM »
i do hope that this is a typo and you fellas mean hack saw.....wtf is an axe saw
lol
Dave
haro, how do you do
motomagII
« Reply #10 on: November 12, 2005, 09:29 AM »
axe on forks would be funny lol
« Reply #11 on: November 12, 2005, 11:31 AM »
yep use an axe
fLA
« Reply #12 on: December 11, 2007, 03:54 PM »
I have a Gyro.. and it won t work properly too.
(I can t fit it properly)
does someone have pictures from a Gyro system fitted, just to see the height of the stem, and if I have to put some "washers" in the headset?
regards,
fLAVIO
