976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 05:15 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Crank help needed...
Author Topic: Crank help needed...  (Read 2586 times)
scary_leary
« on: November 11, 2005, 09:58 PM »
the hole in my sprocket is way bigger than the crank..is this normal?
if not what do i do?
cheers
Lee
Re: Crank help needed...
« Reply #1 on: November 11, 2005, 10:06 PM »
You will need to get a reducer, Think I might have one spare if you need one, is the spindle 19mm.
Offline Rombloke
  • do one
« Reply #2 on: November 11, 2005, 10:10 PM »
bloody hell scary...are you that old school....
and what about a full pic of that hoff
Dave
haro, how do you do
scary_leary
« Reply #3 on: November 11, 2005, 10:16 PM »
yes Dave im that old school... :-[ pics soon (not finished yet)  ;)
t/a the spindle is 18mm will your spacer do?
« Reply #4 on: November 11, 2005, 10:19 PM »
18mm you sure, what cranks are they ?
I'll have a look to see if I can find it, if they are 18mm it will be a bit big, but should be ok.
scary_leary
« Reply #5 on: November 11, 2005, 10:39 PM »
yep they are 18mm
the cranks are GT..same as below
Offline Rombloke
  • do one
« Reply #6 on: November 12, 2005, 12:21 PM »
thats 19mm then im sure....i think its industry standrd size....could be wrong tho....although if i am i will delete this post so it dont matter :)
Dave
haro, how do you do
