Spray Paint?
lazychubs:
i get the ones from carrs paint shop they in 2 pak
and last for ages just dont breath it in tho :buck2:
Philbert:
plasticote will normally tell you on the side of the can whether or not you need lacquer, even if you don't though it shouldn't hurt, as its going to get bashed about. also it will tell you what colour primer to use to get the best out of the colour pigment.
biggest thing to remember to use especially if your going onto metal first is a light dusting of etch primer (zinc primer) first. it'll bite to the metal more so it won't flake, then normal high build primer, flat it down with wet and dry, (no need for a base coat) then your flat coat, lacquer probably optional!
superbikedan:
guys for a standard paint job that will look the nuts
2k all day long, the only one i use, you can coat after coat as many times as you want :)
and the finish will be professional :coolsmiley: err if you are a professional ;D
jimz360:
Sounds good where do you buy your 2K stuff?
superbikedan:
--- Quote from: jimz360 on September 07, 2007, 02:27 PM ---Sounds good where do you buy your 2K stuff?
--- End quote ---
any car paint supllys,
Navigation
[0] Message Index
[*] Previous page
Go to full version
