how to remove a sticker thats fitted and sprayed over with clear? ?
Del:
--- Quote from: nicfred on September 11, 2007, 11:50 AM ---thought about that,i got a big white roll of duct tape :LolLolLolLol: :LolLolLolLol:
--- End quote ---
do you just want to cover it? if so what colour is your frame?
Nicfred:
not really,id prefer to remove it,(but the pri*k has sprayed over it so looks like a complete respray)its on a 1981 looptail quad i got from the states so wanted to do it right,worst bit is its only just been painted so only this sticker spoiling the frame?
but looks like im screwed and will have to get it painted :'( :'(
Del:
what about just rubbing down the clear coat where the sticker is, take the sticker off then get someone to spray over the bit where the sticker was with clear coat again and blending it in, I'm sure that can be done?
Nicfred:
mmmmmmmmmmmm,didnt think of that :-[, suppose i could try that,got nothing to lose,cos if i mess it up i just paint it again :LolLolLolLol: :LolLolLolLol:
here goes then angle grinder out,goggles down 8) ,here goes >:D :LolLolLolLol: :LolLolLolLol:
thanx :daumenhoch:
ill give it a bash
Del:
get a before and after pic, I'd be quite interested if you manage to do it.
Navigation
[0] Message Index
[*] Previous page
Go to full version
