Removing a rounded stem bolt.
<< < (3/3)
bof:
Are you trying to save the stem,. if you are just get a nice sharp ( New maybe Ti coated) drill bit put a punch mark in the stem boltand drill into the bolt head , I know you said you had tried but it sounds like you drill bit was goosed , a nice sharp drill bit should cut through a stem bolt no problem. Or if you dont want to save the stem get an angle grinder and cut the stem top off and knock the wedge bolt out .  :)
mattbus:
get some of these buddy:
http://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set
best investment i ever made, got me out the brown stuff a few times :)
zed4130:
ive had this, i dremmaled the edges flat on 2 sides ,  and then uses a spanner,
mattbus:
--- Quote from: billstup on September 11, 2007, 08:06 PM ---Pair of stilsons req, piece of piss with them  :daumenhoch:
--- End quote ---
2 bits of cheese?              ;)
Dark Diggler:
--- Quote from: bof on September 11, 2007, 08:18 PM ---definitely stilsons . Netto have some for 2.99  :)
--- End quote ---
Did you ask for a discount Gov  ::)
Navigation
[0] Message Index
[*] Previous page
Go to full version
