976288 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 10, 2026, 06:41 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  New School Flight Help Please
Author Topic: New School Flight Help Please  (Read 1709 times)
Offline Haro82
« on: September 16, 2007, 02:34 PM »
Just got some new school twin pinch flights. I might be being a bit stupid here but what is the blue shim that comes with them for ? I presume it goes over the bb spindle inside the BB but why would you need it ?
Any help appreciated .
Andy.
Offline Moose
Re: New School Flight Help Please
« Reply #1 on: September 16, 2007, 02:50 PM »
Blue shim? Do you mean the spacer tube? :-\
Offline Haro82
« Reply #2 on: September 16, 2007, 02:59 PM »
yes probably. Whats it to space?
Offline Moose
« Reply #3 on: September 16, 2007, 03:05 PM »
It's there to stop you 'pinching' the bearings when you tighten the crank arms on. You can do without it, but it depends if you want free-spinning cranks or not.
« Last Edit: September 16, 2007, 03:07 PM by Moose »
Offline Haro82
« Reply #4 on: September 16, 2007, 03:10 PM »
Ahh, I understand now. It just looked to me that it was a little bit big, so I was thinking that when I put the bottom bracket cups in they might not fit snug on the bottom bracket with the spacer in.
I better put it in then  :daumenhoch:
Cheers for the info, Moose.
Andy
Offline Moose
« Reply #5 on: September 16, 2007, 03:39 PM »
Andy
you might need to trim the spacer down if it is a little bit long so that your cups and bearings fit flush. Did your cranks not come with fitting instructions?  :LolLolLolLol:
Offline Jt
« Reply #6 on: September 16, 2007, 04:06 PM »
Andy
none ive had from am cycles have come with fiting instructions....
Offline Haro82
« Reply #7 on: September 16, 2007, 04:40 PM »
Andy
No fitting instructions with mine  :-[  , from am cycles as well.   Give me a set of Old School ones any day of the week.
Still not sussed out new school stems either   :crazy2:
« Reply #8 on: September 16, 2007, 05:10 PM »
the fitting instuctions are unbelievably bad anyway, i reckon they were written abroad using a translator.
Superkav
« Reply #9 on: September 17, 2007, 09:39 AM »
Check some of the old flight insructions on here or check on line. The BB cups are not supposed to sit flush and the instructions point out that an overlap is common. If you don't use the sleeve you can damage your bearings.
