976290 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 13, 2026, 11:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Redline 401 Crank Arm - Cracked Pinch Bolt
Author Topic: Redline 401 Crank Arm - Cracked Pinch Bolt  (Read 2196 times)
BossHogg
« on: September 17, 2007, 08:04 PM »
Hi all,
I've got this set of single pinch Redline 401's. Bit of rust here and there but pretty good nick overall.........well apart from this crack in the non-drive arm. :(
Anyone know if this damage can be fixed up and made good enough to ride on again?  The crack looks to be in a pretty tricky spot alright.  Could be some issues with any repairs being put under tension in that spot right there, i dunno.
Any expert opinions appreciated.
Cheers - Jim  :daumenhoch:
Re: Redline 401 Crank Arm - Cracked Pinch Bolt
« Reply #1 on: September 17, 2007, 08:08 PM »
Im sure that could be fixed if you know a good tig wilder, but it would take a bit of work to get it looking right  :-\
Or even a good tig welder  ;)
Offline billstup
« Reply #2 on: September 17, 2007, 08:36 PM »
I recon it could be repaired for show purposes, but I wouldn`t like to ride on them  :(
bmx xxx
« Reply #3 on: September 17, 2007, 08:55 PM »
i recon super super glue would do, well worth repairing though, good luck
Offline sawzall
« Reply #4 on: September 17, 2007, 09:09 PM »
that should repair ok,the crack would need to be veed out then tig welded,then the thread would need to be re-tapped ;)
mark 2
« Reply #5 on: September 17, 2007, 09:14 PM »
Be careful with a re-tap if it get's drilled again for the thread you'd lose too much of the original metal and then have to go up a size and knob about with different hardware for that side. Try a little weld and get it filed and polished out then a rechrome.
« Reply #6 on: September 17, 2007, 09:41 PM »
No tapping there surely?   It must be a clearance hole....  Tapped thread is on t'other bit   ;)
As for the repair, stick it in the post to Fuzzynod, have his mate repair it, then I'd say ride on it no worries  :)
Offline sawzall
« Reply #7 on: September 17, 2007, 10:03 PM »
just noticed it was on the non thread side :D
mark 2
« Reply #8 on: September 17, 2007, 10:05 PM »
yes, well spotted :LolLolLolLol:
« Reply #9 on: September 17, 2007, 10:09 PM »
I had a crank arm rewelded (not a 401). The weld was spot on but the heat distorted the spindle boss and it didnt fit over the spindle!! Just a little something to watch out for.
« Reply #10 on: September 17, 2007, 10:13 PM »
Before you go to the expense of welding and rechroming, there is usually a good supply of orphan arms on ebay, might be a cheaper route :daumenhoch:
« Reply #11 on: September 17, 2007, 11:23 PM »
Does this thread, and this comment, answer the "which is better, flights or profiles?" Question?
« Reply #12 on: September 18, 2007, 12:22 AM »
Aye, does a bit don't it?
BossHogg
« Reply #13 on: September 18, 2007, 01:03 PM »
Cheers fella's,
Plenty of food for thought there  :-\
Any ideas on cost of repair and a re-chrome vs cost of an orphan?
I was lookin to use the cranks for a rider but if there's any strength issues, maybe not.
Might just be best looking for another arm what with the cost for repair and re-chrome, and if the thing does warp from the heat and won't fit the spindle then it's neither use nor ornament eh?
Shame not to try a fix though.......
.......Bugger :buck2:
« Reply #14 on: September 19, 2007, 01:07 AM »
Another arm is of course the easiest fix, but for a rider you could always just weld the thing and not bother about a rechrome. It'll hardly notice really. As for the heat distortion, the right welder will keep this to a minimum. Also as the splines are so very coarse, I suspect it'll always fit without much hassle   ;)
gjs
« Reply #15 on: September 22, 2007, 04:28 PM »
I have a pair of 401's that the arm completely snapped off,which I welded back on without rechroming,doesn't get used but I would use for everday riding no jumps etc.The repair for yours would make any difference to the strength of the crank,I don't think :daumenhoch:
