976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 09:31 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  will a bench vice be anygood for pressing bearing cups in?
Author Topic: will a bench vice be anygood for pressing bearing cups in?  (Read 2556 times)
Offline adenough
  • Buzz Killington...
« on: September 20, 2007, 04:23 PM »
 :idiot2:
Re: will a bench vice be anygood for pressing bearing cups in?
« Reply #1 on: September 20, 2007, 06:26 PM »
If it opens wide enough and you can get some pieces of wood between the cups and the jaws then yep  :daumenhoch:
wildwood1971
« Reply #2 on: September 20, 2007, 06:48 PM »
Make sure you freeze the cups over night mate and put some washing up liquid on the edges before you put them in - freezing them slightly reduces the size and makes them sooooooooo much easier to fit.  :daumenhoch:
Paul
« Reply #3 on: September 20, 2007, 07:01 PM »
I dont really understand the question???
Is there any other way to put bearing cups in????
I just fitted a set of headset cups using a bench vice today. No freezing or lube involved at all (but I am crap at putting bikes together "well", even after all this time)
Offline adenough
« Reply #4 on: September 20, 2007, 07:54 PM »
« Reply #5 on: September 20, 2007, 08:02 PM »
3x2 plank, fookin big ammer and twat like tenmen.
Vice, next you will be saying that there are special tools for pressing headsets and bb cups.........proposterous
Offline Dingobmxer
« Reply #6 on: September 20, 2007, 08:04 PM »
Heathens  :2gunsfiring_v1:
 :) DINGO :)
« Reply #7 on: September 20, 2007, 08:08 PM »
what kind of headset and forks are they????? :LolLolLolLol:
Offline Dingobmxer
« Reply #8 on: September 20, 2007, 08:11 PM »
oops wrong pic  :-[ that was me facing the headtube so its square  :coolsmiley:
is this better?
 :) DINGO :)
« Reply #9 on: September 20, 2007, 08:20 PM »
That seems a shame to go to so much effort for a cheap headset!  :LolLolLolLol:
Offline adenough
« Reply #10 on: September 20, 2007, 08:22 PM »
nice bars, what make are they? ::)
« Reply #11 on: September 20, 2007, 08:26 PM »
Flatland them, bet he knocked in the bearings with a hammer and wood though  :LolLolLolLol:
Offline Dingobmxer
« Reply #12 on: September 20, 2007, 08:27 PM »
cant remember?
changed them now for something with a little more "sweep"  :coolsmiley:
 :) DINGO :)
Offline Moose
« Reply #13 on: September 20, 2007, 08:33 PM »
Don't forget the soft jaws, so that you don't damage those anodised headset cups  :daumenhoch:
rarman1
« Reply #14 on: September 20, 2007, 10:43 PM »
 :) DINGO :)
i recently made something like this with some threaded rod, 2 washers, 2 nuts and 2 3"x 3" 10mm plates which were offcuts from a metal works place around the corner to me, cost me £7 to make, let me know if you want me to post a pic and i'll take one tomorrow for you ;)
« Reply #15 on: September 20, 2007, 10:57 PM »
a vice works well. try to soften the blow to the cups though, with some wood or rubber or summat.
Offline Gary72
« Reply #16 on: September 20, 2007, 11:18 PM »
Have used the hydraulic press at work before :crazy2:
darkersomeday
« Reply #17 on: September 20, 2007, 11:29 PM »
the only thing to watch out for when using a vice for this is the axle alignment will be out and theres nothing to hold the spacer in place,
try pushing the cups in with the axle in place by swapping the vice from one side of the cup/bearing to the other, like 1 turn/squeeze on eack side,
good luck,
Offline adenough
« Reply #18 on: September 20, 2007, 11:33 PM »
 :D done it to my quality spec ( if it looks right, it is right)  :LolLolLolLol:
