RUSTED IN SEAT POST REMOVAL???
<< < (2/2)
darkersomeday:
--- Quote from: Oberonspacefruit on September 25, 2007, 12:20 PM ---can you soak it in diesel?
i put my frame in a big box, plastic liner, left it in diesel for a week.
then the post in the vice, and twist the frame.
heat can help too.
another method is to cut it off at the frame level, and put a hacksaw blade in the tube and cut it into 1/4's, then chisel it out. extremely time consuming though.
--- End quote ---
all good advice, worked for me :daumenhoch:
the warpig i just got had a post fully seized in there, soaked in diesel for 3 days, try feeding some through the expansion hole in the bb with the frame turned upside down,
so it runs down onto the bottom of the seatpost,
then put the seat post in the vice, and use the frame to get leverage, tiny bit at a time,
we had to put the blowtorch on the warpig frame like, we heated up the seat tube till it was near glowing and it eventually let go :daumenhoch:
Superkav:
Sounds crazy but you can hit the tube further down into the frame to loosen it (depending on how much is protruding). If you don't want to save the post drill a hole through it and put a bolt through the hole, that way it can't go in too deep when you whack it.
Works for me
djgivvinup:
Av u tried a big fack orf stilson/pipe wrench??  I've took a few stuck seat posts out like wiv em,  it'll more than likely trash your seatpost but you'll get the bugger out!!   :daumenhoch:
sawzall:
if all else fails you will need to get it drilled out using a piller drill,i have done a couple and got another one to do,i tried all the other methods but the seat post is made out of monkey metal and just crumbles as soon as you touch it :tickedoff:
lazychubs:
cant large help ya paul
or ya scared he will kill the vdc lol
spesh the way he just cut huge holes in me buggy that time
ill pass on him i thinks lol
Navigation
[0] Message Index
[*] Previous page
Go to full version
